Do I need both the sensor and binary sensor for alerts
Like many people here, I started small and have continuted to add and tweak my sensors, binary sensors, template, automation and alerts. I just came across this in my setup and could not remember if I did this on purpose, or never got around to finishing trimming down my sensors,
So I guess my question is would you use the sensor for your alert, the binary sensor(s) for your alerts, both, neither, etc
in my sensors.yaml
	  downstairs_smoke_detector:
        value_template: >-
          {%- if is_state("sensor.smoke_detector_downstairs_alarm_type", "0") %}
            Idle
             {%else%}
              {%- elif is_state("sensor.smoke_detector_downstairs_alarm_type", "1") %}
                Fire
              {%- elif is_state("sensor.smoke_detector_downstairs_alarm_type", "2") %}
                C02
              {%- elif is_state("sensor.smoke_detector_downstairs_alarm_type", "12") %}
                Testing
              {%- elif is_state("sensor.smoke_detector_downstairs_alarm_type", "13") %}
                Idle
              {% else %}
                Unknown
              {%- endif %}
            {%endif%}
        friendly_name: 'Downstairs Smoke Alarm'
        entity_id: sensor.smoke_detector_downstairs_alarm_type
in my binary sensors
   sensors:
     downstairs_smoke_detector_smoke:
       value_template: "{{ is_state('sensor.smoke_detector_downstairs_alarm_type', '1') }}"
       friendly_name: "Smoke Detector - Smoke"
       device_class: smoke
   sensors:
     downstairs_smoke_detector_co2:
       value_template: "{{ is_state('sensor.smoke_detector_downstairs_alarm_type', '2') }}"
       friendly_name: "Smoke Detector - CO2"
       device_class: gas
   sensors:
     downstairs_smoke_detector_testing:
       value_template: "{{ is_state('sensor.smoke_detector_downstairs_alarm_type', '12') }}"
       friendly_name: "Smoke Detector - Testing"
my alerts
    name: Downstairs Smoke Alarm - Smoke Detected
    done_message: Smoke has been cleared
    entity_id: binary_sensor.downstairs_smoke_detector_smoke
    state: 'on'
    repeat: 5
    can_acknowledge: True
    notifiers:
      - ios_pauls_iphone
      - ios_tracys_iphone
      - sony_tv
  smoke_detector_co2:
    name: Downstairs Smoke Alarm - CO2 Detected
    done_message: CO2 has been cleared
    entity_id: binary_sensor.downstairs_smoke_detector_co2
    state: 'on'
    repeat: 5
    notifiers:
      - ios_pauls_iphone
      - ios_tracys_iphone
      - sony_tv
  smoke_detector_test:
    name: Downstairs Smoke Alarm - Testing
    done_message: Smoke Alarm Testing completed
    entity_id: binary_sensor.downstairs_smoke_detector_testing
    state: 'on'
    repeat: 5
    notifiers:
      - ios_pauls_iphone
      - ios_tracys_iphone
      - sony_tv
I’d just use the sensor for the automations. Probably leave the binary sensors for quick viewing. Or i’d remove the binary sensors.
probably could clean this up a bit too:
        value_template: >
          {% set statemap = {
            "0" : "Idle",
            "1" : "Fire",
            "2" : "C02",
            "12" : "Testing",
            "13" : "Idle" } %}
          {% set key = states("sensor.smoke_detector_downstairs_alarm_type") %}
          {{ statemap[key] if key in statemap.keys() else "Unknown" }}
What type of detectors do you have? I’m looking at First Alerts and wondering how good these are.
I just installed one and these values match with what I’m seeing with a First Alert Smoke/CO2 detector.
