Do I really need 1 automation per button of my 6 gang loratap controller? (therefore 18 automations for 1 device)
RIght now I m creating one automation for each button on my 6 gang button from loratap:
alias: 6 gang escritorio, bt2, 1 click
description: ""
triggers:
  - domain: mqtt
    device_id: 44ae6c9b9e5b7483d6f09fb1f901f877
    type: action
    subtype: 2_single
    trigger: device
conditions: []
actions:
  - action: script.persiana_quarto_patch
    metadata: {}
      command: open
      device_name: persiana escritorio
mode: single
so I get a bunch of automations just for 1 button, they tend to pollute things.
Is there a way to add 1 call for each button (there are 6, each with single click, double click and hold) in a way that it does not need to create 6*3 automations?
Hi @vespuccio
You can have multiple triggers in 1 automation. One trigger for each button.
Each trigger can be given a trigger id.
You can then use a Choose action to perform actions depending on the trigger ids
Hello vespuccio,
You can write a blueprint, which is basically 1 automation, then call that multiple times with different entity names.
Here’s how I deal with my LoraTap 4-way remote, note there is only one hold event per remote, not per button:
- id: a9918825-dc29-409b-ba37-832f9dd0f6e6
  alias: Dining Button Events
  triggers:
  - trigger: state
    entity_id: event.dining_button_action
    to: ~
  conditions:
  - condition: template
    value_template: "{{trigger.from_state.state != 'unavailable'}}"
  actions:
  - choose:
    - conditions:
        value_template: "{{trigger.to_state.attributes.event_type == '1_single'}}"
      sequence:
      - repeat:
          count: 6
          sequence:
          - action: media_player.volume_up
              entity_id:
              - media_player.dining_zone
          - delay: 0.1
    - conditions:
        value_template: "{{trigger.to_state.attributes.event_type == '1_double'}}"
      sequence:
      - repeat:
          count: 9
          sequence:
              entity_id:
          - delay: 0.1
    - conditions:
        value_template: "{{trigger.to_state.attributes.event_type == '2_single'}}"
      sequence:
      - repeat:
          count: 6
          sequence:
          - action: media_player.volume_down
              entity_id:
          - delay: 0.1
    - conditions:
        value_template: "{{trigger.to_state.attributes.event_type == '2_double'}}"
      sequence:
      - repeat:
          count: 9
          sequence:
              entity_id:
          - delay: 0.1
    - conditions:
        value_template: "{{trigger.to_state.attributes.event_type == '3_single'}}"
      sequence:
      - action: media_player.media_next_track
          entity_id:
          - media_player.lounge_zone
    - conditions:
        value_template: "{{trigger.to_state.attributes.event_type == '3_double'}}"
      sequence:
      - action: media_player.media_previous_track
          entity_id:
    - conditions:
        value_template: "{{trigger.to_state.attributes.event_type == '4_single'}}"
      sequence:
      - action: media_player.media_play_pause
          entity_id:
    - conditions:
        value_template: "{{trigger.to_state.attributes.event_type == 'hold'}}"
      sequence:
      - action: media_player.toggle
          entity_id:
      - action: media_player.select_source
          entity_id:
          source: Main Zone Sync
Also this is using the new Z2M event entities, not the legacy action entities.
Yes, trigger IDs and choose actions are the way. I’d paste my 6 button loratap automation but it’s too huge. Smart Home Junkie has an excellent tutorial video on this on YouTube.
I have several 4 gang and 6 gang buttons running under ZHA and they’re working great. And with short, double and long press triggers that gives me more than enough options for my needs.
It annoys me that LoraTap don’t implement a hold and a release event per button (like Aqara buttons). That would make volume control a lot easier. Increase volume in a loop while the button is held until release.
Same. I started with Aqara mini buttons and have replaced several with Loratap multi-gang, but having the release trigger for long press is handy. I hadn’t thought of using it for volume control though!
