Do something between two triggers
I have a remote that sends a signal when starting a long press and another signal when the long press ends. I want to use this to do something like “while in long press, increase luminosity” which translates to:
  • When the long press starts, begin increasing luminosity of a light
  • When the long press stops, stop increasing the luminosity of a light
However I’m clueless on how to implement this rule in HASS, any ideas? :confused:
I think this would be two automations and a script:
Automation 1 -
- alias: Lights up on long press
    platform: state
    entity_id: YOUR REMOTE
    to: LONG PRESS
    service: homeassistant.turn_on
    entity_id: script.lights_up
Automation 2 -
- alias: Lights stop changes
    platform: state
    to: LONG PRESS STOPPED
    service: homeassistant.turn_off
Script -
lights_up:
  sequence:
    service: light.turn_on
      entity_id: YOUR LIGHT
      transition: 10
      brightness: 200
(syntax may be a bit wrong as it is totally off the top of my head and I’m not at a computer to check)
The idea is that you have a script that when activated gradually ups the lights to full over 10 seconds.
Activate the script on long press, stop it on long press release.
Hope this helps.
