Hi there,
I’ve been playing with homeassistant for a bit. I love the idea of it, but haven’t been able to get it working properly. I’m on reinstall number 4 and I always have this same issue. Please help!
I just did a complete reinstall. Here’s what that looked like in my case:
docker stop homeassistant
docker rm homeassistant
rm -rf /storage/data/homeassistant
docker run -d --name homeassistant --privileged \
--restart=unless-stopped -e TZ=GB \
-v /storage/data/homeassistant:/config \
--network=host \
ghcr.io/home-assistant/home-assistant:stable
Without running anything else, or even trying to connect to the interface, I peek into the /storage/data/homeassistant folder and see three things:
- It’s there. So it’s getting recreated by docker as part of the install
- The brand new structure contains corrupted db entries:
home-assistant_v2.db.corrupt.2022-11-10T15:30:24.399590+00:00
- The first line of the log is already indicating IO errors:
2022-11-10 15:30:21.382 ERROR (Recorder) [homeassistant.components.recorder.core] Error during connection setup: (sqlite3.OperationalError) disk I/O error
As near as I can tell, I’m properly following the directions here: Linux - Home Assistant
Write location has appropriate permissions (docker is creating the folder) and loads of space (5.8TB free)
What am I missing?
Thanks!
