Oh, got it. here it is (only partially):
[17/07/21 10:58:52] /home/pi pi@raspberrypi% docker container logs homeassistant
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[22:07:27] INFO: Setup udev backend inside container
starting version 3.2.9
[22:07:27] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2021-04-15 22:33:39 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 314, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 546, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'invalid HTTP method'"
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
2021-04-15 23:02:11 ERROR (Thread-8) [root] Uncaught thread exception
File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.8/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.8/site-packages/xiaomi_gateway/__init__.py", line 180, in _listen_to_msg
data, (ip_add, _) = self._mcastsocket.recvfrom(SOCKET_BUFSIZE)
OSError: [Errno 9] Bad file descriptor
Unable to find configuration. Creating default one in /config
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[fix-attrs.d] done.
[23:02:34] INFO: Setup udev backend inside container
[23:02:35] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
2021-04-15 23:54:54 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-15 23:56:11 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 00:01:25 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 00:10:02 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 00:25:14 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 00:32:22 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 00:40:28 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 00:55:47 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 01:11:03 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 01:26:52 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 01:32:22 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 01:42:03 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 01:57:05 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 02:12:28 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 02:27:34 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 02:32:23 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 02:41:39 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 02:42:36 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 02:45:01 WARNING (MainThread) [homeassistant.components.duckdns] Updating DuckDNS domain failed: oriharel
2021-04-16 02:57:37 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 03:12:54 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 03:28:02 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 03:32:23 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 03:43:14 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 03:58:15 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 04:14:03 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 04:29:20 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 04:32:24 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 04:44:49 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 05:00:19 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 05:15:27 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 05:30:29 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 05:32:25 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 05:45:41 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 06:01:02 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 06:16:10 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 06:31:13 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 06:32:25 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 192.168.0.110
2021-04-16 13:55:01 WARNING (MainThread) [homeassistant.components.duckdns] Updating DuckDNS domain failed: oriharel
2021-04-16 14:54:24 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 802926937bc4715efa3e9de446b0640cd3782fae1b9ae0f5abf2422a2111fa89 from 2.55.143.179
2021-04-16 14:54:28 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 2-55-143-179.orange.net.il (2.55.143.179). (HomeAssistant/Android 2021.4.1-658)
2021-04-16 14:54:28 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 31-154-143-179.orange.net.il (2.55.143.179). (Mozilla/5.0 (Linux; Android 11; Pixel 4 Build/RQ2A.210405.005; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/89.0.4389.105 Mobile Safari/537.36)
2021-04-16 14:55:11 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update Pixel 4 non-registered sensor: 95de44e1b6d292969a74dbd70acb97a79aae22aa20750b5ce50cf14e231fa6b2_battery_level
2021-04-16 14:55:11 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update Pixel 4 non-registered sensor: 95de44e1b6d292969a74dbd70acb97a79aae22aa20750b5ce50cf14e231fa6b2_battery_state
2021-04-16 14:55:11 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update Pixel 4 non-registered sensor: 95de44e1b6d292969a74dbd70acb97a79aae22aa20750b5ce50cf14e231fa6b2_is_charging
2021-04-16 14:55:11 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update Pixel 4 non-registered sensor: 95de44e1b6d292969a74dbd70acb97a79aae22aa20750b5ce50cf14e231fa6b2_charger_type
2021-04-16 14:55:11 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update Pixel 4 non-registered sensor: 95de44e1b6d292969a74dbd70acb97a79aae22aa20750b5ce50cf14e231fa6b2_battery_temperature
2021-04-16 17:43:43 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from IGLD-84-228-29-68.inter.net.il (84.228.29.68). (Mozilla/5.0 (Linux; Android 11; Pixel 4 Build/RQ2A.210405.005; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/89.0.4389.105 Mobile Safari/537.36)
2021-04-16 17:54:38 ERROR (Thread-21) [plexapi] http://82.94.168.36:8443: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2021-04-16 17:54:55 ERROR (MainThread) [plexwebsocket] Websocket connection failed, retrying in 15s: Cannot connect to host 192-168-0-116.0026adc10d0e453999422b7d6f87fbab.plex.direct:32400 ssl:default [Try again]
2021-04-16 17:58:09 ERROR (Thread-27) [plexapi] http://82.94.168.34:8443: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2021-04-16 19:35:19 WARNING (Thread-14) [pychromecast.socket_client] [Bedroom TV(192.168.0.112):8009] Heartbeat timeout, resetting connection
2021-04-16 19:35:49 ERROR (Thread-14) [pychromecast.socket_client] [Bedroom TV(192.168.0.112):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.0.112', 8009)), retrying in 5.0s
2021-04-16 19:43:44 WARNING (Thread-28) [pychromecast.socket_client] [Kitchen TV(192.168.0.110):8009] Heartbeat timeout, resetting connection
2021-04-16 19:44:00 ERROR (Thread-28) [pychromecast.socket_client] [Kitchen TV(192.168.0.110):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.0.110', 8009)), retrying in 5.0s
2021-04-16 22:02:42 ERROR (MainThread) [aiohttp.server] Error handling request
2021-04-16 22:21:42 ERROR (Thread-14) [pychromecast.socket_client] [Bedroom TV(192.168.0.112):8009] Failed to connect. No retries.
2021-04-16 22:21:42 ERROR (Thread-5) [root] Uncaught thread exception
self.run()
2021-04-16 22:21:43 ERROR (Thread-28) [pychromecast.socket_client] [Kitchen TV(192.168.0.110):8009] Failed to connect. No retries.
[fix-attrs.d] done.
[22:22:07] INFO: Setup udev backend inside container
[22:22:07] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
2021-04-16 22:22:43 WARNING (MainThread) [homeassistant.components.http] The 'base_url' option near /config/configuration.yaml:18 is deprecated, please remove it from your configuration
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.config] Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/fullchain.pem'
not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/privkey.pem'. (See /config/configuration.yaml, line 18). Please check the docs at https://www.home-assistant.io/integrations/http
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Invalid config.
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of system_log. Setup failed for dependencies: http
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Setup failed for system_log: Could not set up all dependencies.
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of image. Setup failed for dependencies: http
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Could not set up all dependencies.
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of api. Setup failed for dependencies: http
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Setup failed for api: Could not set up all dependencies.
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of auth. Setup failed for dependencies: http
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Setup failed for auth: Could not set up all dependencies.
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of alexa. Setup failed for dependencies: http
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Setup failed for alexa: Could not set up all dependencies.
2021-04-16 22:22:43 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of webhook. Setup failed for dependencies: http
