Docker list lost after docker re-installation in Supervised mode
I have updated the docker to newest version. It was working 6 months ago. I have applied same commands to update it. However after rebooting the Supervised system a few times, I see only 1 docker process while I expect at least 7 processes. Is there a way to get it back?
  477  apt update
  478  apt upgrade
  479  apt-cache policy docker-ce
  480  apt-cache policy docker-ce-cli
  481  apt-cache policy containerd.io
  482  apt purge -y docker-ce docker-ce-cli containerd.io
  483  shutdown -r now
  484  docker -p
  485  docker
  486  ls
  487  pwd
  488  cd ..
  489  ls
  490  history
  491  docker ps
  492  apt update
  493  apt upgrade
  494  service docker stop
  495  apt-get install docker-ce docker-ce-cli containerd.io
  496  shutdown -r now
  497  docker ps
  498  docker ps
  499  docker ps
  500  reboot
  501  history
root@raspberrypi:~# docker ps
CONTAINER ID   IMAGE                                                    COMMAND   CREATED         STATUS          PORTS                                   NAMES
a5dad811290c   ghcr.io/home-assistant/armv7-hassio-observer:2021.10.0   "/init"   19 months ago   Up 15 minutes   0.0.0.0:4357->80/tcp, :::4357->80/tcp   hassio_observer
Have you tried re-installing Supervised?
No. It will lost a lot of HomeAssistant settings.
If I re-do it, can I overwrite all files in folder /usr/share/hassio by a backup file? Will it work?
I see a list of containers after execution: docker images
ghcr.io/home-assistant/armv7-hassio-supervisor      2023.06.2   61177a3575b1   17 hours ago    321MB
ghcr.io/home-assistant/armv7-hassio-supervisor      latest      61177a3575b1   17 hours ago    321MB
ghcr.io/home-assistant/raspberrypi4-homeassistant   2023.6.1    313f79730c67   5 days ago      1.57GB
ghcr.io/home-assistant/home-assistant               stable      48daa1523ba0   5 days ago      1.57GB
ghcr.io/home-assistant/armv7-hassio-cli             2023.05.0   b201413acf64   9 days ago      91.3MB
ghcr.io/hassio-addons/glances/armv7                 0.19.2      28d28f61b08e   3 weeks ago     90.3MB
ghcr.io/hassio-addons/appdaemon/armv7               0.13.0      069b1a21b2d6   4 weeks ago     101MB
ghcr.io/hassio-addons/influxdb/armv7                4.7.0       81a562724929   4 weeks ago     483MB
homeassistant/armv7-addon-mariadb                   2.6.1       4eceeea2f39f   5 weeks ago     263MB
ghcr.io/home-assistant/armv7-hassio-audio           2023.04.2   7365a5822485   7 weeks ago     126MB
homeassistant/armv7-addon-configurator              5.6.0       b8eebca79e39   7 weeks ago     168MB
homeassistant/armv7-addon-samba                     10.0.0      69dbec36085f   11 months ago   110MB
sabeechen/hassio-google-drive-backup-armv7          0.108.2     967fab1909f4   12 months ago   283MB
homeassistant/armv7-addon-duckdns                   1.15.0      040d59a2f3fc   12 months ago   87.4MB
ghcr.io/home-assistant/armv7-hassio-dns             2022.04.1   ece83746c8b3   13 months ago   72.4MB
ghcr.io/hassio-addons/grafana/armv7                 7.5.2       fb02b3945764   14 months ago   480MB
ghcr.io/hassio-addons/ssh/armv7                     10.1.1      64971fda5e83   15 months ago   341MB
ghcr.io/hassio-addons/phpmyadmin/armv7              0.7.1       def8698fc016   15 months ago   112MB
ghcr.io/home-assistant/armv7-hassio-multicast       2022.02.0   d491cf19fe51   15 months ago   58.8MB
ghcr.io/home-assistant/armv7-hassio-observer        2021.10.0   a880edc5261d   20 months ago   65.9MB
ghcr.io/hassio-addons/portainer/armv7               2.0.0       bc0476b479e7   22 months ago   184MB
How can I execute the containers in a proper way?
Reinstalling the .deb is perfectly safe. You don’t loose any home assistant settings. But if you have not updated HA for 6 months, you will need to do a lot of cleaning. Several database schema changes, a lot of breaking changes…
