My homemade alarm system sends out a JSON object on MQTT, and one value in this object is clear
. But if I define a sensor with:
value_template: '{{ value_json.clear }}'
No value is received, however the examples below works just fine:
value_template: '{{ value_json.fault }}'
value_template: '{{ value_json.tamper }}'
It also works if I change the clear
value to something else, like clear_to_arm
Does value_json.clear
have some kind of special meaning?
Here is the full JSON object sent by the security system:
"attempts": 0,
"battery_v": 0.0,
"clear": true,
"clear_to_arm": true,
"fault": false,
"state": "disarmed",
"status": {
"cabinet_temp": true,
"code_attempts": true,
"ext_tamper_ok": true,
"healthchecks_ok": true,
"mains_power_ok": true,
"mqtt_connected": true,
"panel_tamper_ok": true,
"sensor_door1_battery": true,
"sensor_door2_battery": true,
"sensor_door3_battery": true,
"sensor_motion2_alive": true,
"sensor_panel_tamper_alive": true,
"sensor_panel_tamper_battery": true,
"sensor_water_leak1_alive": true,
"sensor_water_leak1_battery": true,
"siren1_not_blocked": true,
"siren1_output_ok": true,
"siren2_not_blocked": true,
"siren2_output_ok": true,
"zigbee_bridge": true,
"zwave_bridge": true
"tamper": false,
"temperature": 21.5,
"triggered": {
"timestamp": null,
"zone": null
"zones": {
"door1": false,
"door2": false,
"door3": false,
"emergency": false,
"ext_tamper": false,
"motion2": false,
"panel_tamper": false,
"panic": false,
"water_leak1": false,
"zone01": false
