Sorry if this has been asked, but I have been loving this Olimex ESP32-POE-ISO-EA as a bluetooth proxy when connected over POE ethernet to have the extended bluetooth range to my ruuvi temperature sensor outside in my well house but was wondering if I could use the wifi on the board and power it with USB instead of using the POE. It seems like I could just replace this part of the config…
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
power_pin: GPIO12
# Optional manual IP
manual_ip:
static_ip: 10.0.150.237
gateway: 10.0.150.1
subnet: 255.255.255.0
with this…
wifi:
ssid: !secret wifi_ssid
manual_ip:
gateway: 10.0.150.1
dns1: 10.0.150.1
ap:
and expect it to work?
I already have proven that I don’t need POE (as mentioned in another thread) but am currently using a wifi to ethernet adapter and that works fine, but feel like I might be making this more complicated than it needs to be. It was a bit challenging to get the original setup working, so am kind of afraid to mess with it unless someone else has already tried it.
