Does the AVM FRITZ!SmartHome Integration support DECT Roller Shutters?
Hi, I’m looking for a roller shutter system, that I can integrate in my home assistant. I found a DECT using product, so that I can connect it without bridge to my FritzBox. I cannot find the information if the Fritz Smart Home Integration does support these dect roller shutters.
Can anybody help me?
Thanks a lot
Raipel
I have 2 Dect roller shutter motors from Becker running. Home assistant recognizes them, but nothing can be controlled directly.
However, I can recommend the Shelly 2.5 which I will now use for the other shutters with me. These can also be controlled directly with home assistant.
In addition, you can use the Shellys much cheaper roller shutter motors. The DECT motors cost about four times as much as a simple shutter motor.
brgds
Holger
Hi! Have you found a solutin to control the DECT Becker shutters with home assistant? I thought about using a shelly 1 (the can both be controlled using DECT an a wirde single switch) but the in my case not working binary sensor (always closed, regardless the position) would make this uncomfortable… All the best and thanks in advance!
Hi. Yes i can control the DECT Becker shutters via the addon NodeRed and to install the node node-red-contrib-shelly. With this node you have full control to the Dect shutters.
