The internet thinks it does, but I can’t add it in the integrations. I’m using bluetooth to control my govee smart plugs - maybe there’s a better way?
I don’t know what version of Home Assistant you have installed, but recent ones should display a section that gives you access to the information about it under Settings.
Are you using a bluetooth device that is on the Known to Work list.
A suggestion… Use an ESPHome Bluetooth Proxy instead. It works faster that whatever bluetooth stack is generally running insiude your computer.
UPDATE…
Sorry, I see you said it was a Green which is on the good list. (I still suggest a ESPHome BT Proxy)
Nabu Casa Support - Does Home Assistant Green have Zigbee, Thread, Wi-Fi, or Bluetooth?
EDIT: Fixed typo in link
That link is broken
