Nope. I never did figure it out. I pivoted to using node-red to send the entire image to doods and then test the returned results against an arbitrary polygon to see if any points lay within the polygon. It does what I was looking for but it took a fair amount of fussing about.
Here is the node-red flow I use. It watches my three exterior cameras for a doods image scan result. It checks the result and if a person is indicated, it then tests if any of the four x/y points for the person with the highest detection confidence exist within the defined polygon for the camera. If it does, it sets an appropriate sensor to true for five seconds and then resets it.
"id": "8199ce8bd50946ba",
"type": "tab",
"label": "Camera Person Detections",
"disabled": false,
"info": "",
"env": []
"id": "042aad9bc2f6fdb9",
"type": "ha-binary-sensor",
"z": "8199ce8bd50946ba",
"name": "Inform Home Assistant of Camera1 detection state",
"entityConfig": "ede7114924032712",
"version": 0,
"state": "payload",
"stateType": "msg",
"attributes": [],
"inputOverride": "allow",
"outputProperties": [],
"x": 1590,
"y": 360,
"wires": [
"id": "1f3ea010195f0d7f",
"type": "server-state-changed",
"name": "Camera2 Detections",
"server": "6585493a.4a98f8",
"version": 4,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "image_processing.doods_camera2_last_eventid",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "num",
"haltifstate": "0",
"halt_if_type": "num",
"halt_if_compare": "gt",
"outputs": 2,
"output_only_on_state_change": false,
"for": "0",
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": true,
"ignoreCurrentStateUnavailable": true,
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 90,
"y": 420,
"wires": [
"721556fed3b2e251"
"id": "b180b4c6aae10e24",
"name": "Camera3 Detections",
"version": 4,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "image_processing.doods_camera3_last_eventid",
"haltifstate": "0",
"outputs": 2,
"for": "0",
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 90,
"y": 480,
"wires": [
"721556fed3b2e251"
"id": "721556fed3b2e251",
"type": "function",
"name": "Remove extraneous data",
"func": "const entity_id = msg.data.entity_id;\nconst matches = msg.data.new_state.attributes.matches;\nvar index = null;\nswitch (entity_id) {\n case \"image_processing.doods_camera1_last_eventid\":\n index = 1;\n break;\n case \"image_processing.doods_camera2_last_eventid\":\n index = 2;\n break;\n case \"image_processing.doods_camera3_last_eventid\":\n index = 3;\n break;\n};\n//node.warn({ \"entity_id\": entity_id, \"index\": index });\nreturn { payload: { entity_id: entity_id, index: index, matches: matches } };",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 330,
"y": 420,
"wires": [
"63bf39d22c670fcd"
"id": "b696b8b77c063e40",
"name": "Camera1 Detections",
"version": 4,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "image_processing.doods_camera1_last_eventid",
"haltifstate": "0",
"outputs": 2,
"for": "0",
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 90,
"y": 360,
"wires": [
"721556fed3b2e251"
"id": "63bf39d22c670fcd",
"type": "switch",
"name": "Were people detected?",
"property": "payload.matches.person",
"rules": [
"t": "nnull"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 590,
"y": 420,
"wires": [
"68eab4ac5c458725",
"2289292948443639"
"d42fe572aa92dab7"
"id": "68eab4ac5c458725",
"type": "debug",
"name": "debug 6",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 800,
"y": 300,
"wires": []
"id": "1c01861e5e65fca0",
"type": "debug",
"name": "debug 7",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1060,
"y": 540,
"wires": []
"id": "d42fe572aa92dab7",
"type": "function",
"name": "No people detected",
"func": "const state = false;\nconst index = msg.payload.index;\nreturn { payload: { index: index, state: state } };",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 870,
"y": 480,
"wires": [
"1c01861e5e65fca0",
"57697b957810e845"
"id": "57697b957810e845",
"type": "switch",
"name": "Route to correct sensor",
"property": "payload.index",
"rules": [
"t": "eq",
"v": "1",
"vt": "num"
"t": "eq",
"v": "2",
"vt": "num"
"t": "eq",
"v": "3",
"vt": "num"
"checkall": "false",
"repair": false,
"outputs": 3,
"x": 1250,
"y": 420,
"wires": [
"31315a2c0ce3f89b",
"042aad9bc2f6fdb9"
"3a886e3e99b0111f",
"8a5e3a6d4a8eefd8"
"7860f5b35db9965b",
"702ae24513cea079"
"id": "31315a2c0ce3f89b",
"type": "debug",
"name": "debug 8",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1460,
"y": 240,
"wires": []
"id": "3a886e3e99b0111f",
"type": "debug",
"name": "debug 9",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1460,
"y": 280,
"wires": []
"id": "7860f5b35db9965b",
"type": "debug",
"name": "debug 10",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1460,
"y": 320,
"wires": []
"id": "2289292948443639",
"type": "function",
"name": "Is person in zone?",
"func": "/*\n * Test each vertex point in box array for each person in person array.\n * If any point exists inside zone, consider person to be in zone and\n * set state to TRUE\n */\n\nvar state = false;\nconst index = msg.payload.index;\nconst people = msg.payload.matches.person;\n\nvar zone = [[],[],[],[]];\nzone[1] = [\n [0.000, 0.648],\n [0.460, 0.336],\n [0.589, 0.311],\n [0.589, 0.658],\n [0.723, 0.658],\n [0.723, 0.498],\n [0.590, 0.498],\n [0.590, 0.311],\n [1.000, 0.311],\n [1.000, 0.437],\n [0.941, 0.437],\n [0.941, 0.552],\n [1.000, 0.552],\n [1.000, 0.800],\n [0.895, 0.800],\n [0.895, 1.000],\n [0.000, 1.000]];\nzone[2] = [\n [0.000, 0.330],\n [0.417, 0.146],\n [0.537, 0.198],\n [0.537, 0.318],\n [0.574, 0.318],\n [0.574, 0.224],\n [0.700, 0.304],\n [1.000, 0.510],\n [1.000, 1.000],\n [0.000, 1.000]];\nzone[3] = [\n [0.365, 0.000],\n [1.000, 0.000],\n [1.000, 1.000],\n [0.150, 1.000]];\n\n/*\n * Performs the even-odd-rule Algorithm (a raycasting algorithm) to find out whether a point is in a given polygon.\n * This runs in O(n) where n is the number of edges of the polygon.\n *\n * @param {Array} polygon an array representation of the polygon where polygon[i][0] is the x Value of the i-th point and polygon[i][1] is the y Value.\n * @param {Array} point an array representation of the point where point[0] is its x Value and point[1] is its y Value\n * @return {boolean} whether the point is in the polygon (not on the edge, just turn < into <= and > into >= for that)\n */\nconst pointInPolygon = function (polygon, point) {\n //A point is in a polygon if a line from the point to infinity crosses the polygon an odd number of times\n let odd = false;\n //For each edge (In this case for each point of the polygon and the previous one)\n for (let i = 0, j = polygon.length - 1; i < polygon.length; i++) {\n //If a line from the point into infinity crosses this edge\n if (((polygon[i][1] >= point[1]) !== (polygon[j][1] >= point[1])) // One point needs to be above, one below our y coordinate\n // ...and the edge doesn't cross our Y coordinate before our x coordinate (but between our x coordinate and infinity)\n && (point[0] <= ((polygon[j][0] - polygon[i][0]) * (point[1] - polygon[i][1]) / (polygon[j][1] - polygon[i][1]) + polygon[i][0]))) {\n // Invert odd\n odd = !odd;\n }\n j = i;\n\n }\n //If the number of crossings was odd, the point is in the polygon\n return odd;\n};\n\npeople.forEach((person) => {\n //node.warn({\"person\": person});\n const top = person.box[0];\n const left = person.box[1];\n const bottom = person.box[2];\n const right = person.box[3];\n const box = [[left, top], [right, top], [right, bottom], [left, bottom]];\n\n box.forEach((test_point) => {\n var inside = pointInPolygon(zone[index], test_point);\n if (inside) { state = true };\n //node.warn({ \"inside\": inside, \"x\": test_point[0], \"y\": test_point[1] });\n });\n});\n\nreturn { payload: { index: index, state: state } };\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 870,
"y": 360,
"wires": [
"c527930f9c02eb23",
"8c74125c8ccdb5af",
"57697b957810e845"
"id": "c527930f9c02eb23",
"type": "debug",
"name": "debug 11",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1060,
"y": 300,
"wires": []
"id": "8c74125c8ccdb5af",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "5",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 900,
"y": 420,
"wires": [
"d42fe572aa92dab7"
"id": "8a5e3a6d4a8eefd8",
"name": "Inform Home Assistant of Camera2 detection state",
"entityConfig": "37b5641b58e0566e",
"version": 0,
"state": "payload",
"stateType": "msg",
"attributes": [],
"x": 1590,
"y": 420,
"wires": [
"id": "702ae24513cea079",
"name": "Inform Home Assistant of Camera3 detection state",
"entityConfig": "a41e18550cfa0e1e",
"version": 0,
"state": "payload",
"stateType": "msg",
"attributes": [],
"x": 1590,
"y": 480,
"wires": [
"id": "ede7114924032712",
"type": "ha-entity-config",
"deviceConfig": "",
"name": "camera1_last_eventid_person_detected",
"version": "6",
"entityType": "binary_sensor",
"haConfig": [
"property": "name",
"value": "Camera1 Person Detected"
"property": "icon",
"value": ""
"property": "entity_category",
"value": ""
"property": "device_class",
"value": ""
"resend": false,
"debugEnabled": false
"id": "6585493a.4a98f8",
"type": "server",
"name": "Home Assistant",
"addon": true
"id": "37b5641b58e0566e",
"deviceConfig": "",
"name": "camera2_last_eventid_person_detected",
"version": "6",
"haConfig": [
"property": "name",
"value": "Camera2 Person Detected"
"property": "icon",
"value": ""
"value": ""
"value": ""
"resend": false,
"id": "a41e18550cfa0e1e",
"deviceConfig": "",
"name": "camera3_last_eventid_person_detected",
"version": "6",
"haConfig": [
"property": "name",
"value": "Camera3 Person Detected"
"property": "icon",
"value": ""
"value": ""
"value": ""
"resend": false,
