I’m struggling to get an automation to finish with my garage door
Basically, I’ve got a door contact that announces on 2 speakers that it is open, and then when its closed
I’ve used an IF/THEN/ELSE statement to allow this. which i can get to work with a simple 1 open and 1 close statement
However, when I add a repeat while door open with a delay to keep home assistant saying on speakers the door is open after a set time, it stops the “else” statement “garage door is closed”
This isn’t the end of the world but i’d like to know why and how to fix for future automations
any ideas?
alias: "garage door "
description: ""
- platform: state
entity_id:
- binary_sensor.garage_door_sensor_door
to: "on"
- platform: state
entity_id:
to: "off"
condition: []
- if:
- condition: state
entity_id: binary_sensor.garage_door_sensor_door
state: "on"
then:
- repeat:
sequence:
- service: media_player.play_media
entity_id: media_player.max_s_speaker
media_content_id: >-
media-source://tts/cloud?message=The+Garage+door+is+open&language=en-US&voice=JennyNeural
media_content_type: provider
metadata:
title: The Garage door is open
thumbnail: https://brands.home-assistant.io/_/cloud/logo.png
media_class: app
children_media_class: null
navigateIds:
- media_content_type: app
media_content_id: media-source://tts
- media_content_type: provider
entity_id: media_player.kitchen_display
metadata:
media_class: app
navigateIds:
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
until:
- condition: state
state: "off"
else:
media-source://tts/cloud?message=The+Garage+door+is+closed&language=en-US&voice=JennyNeural
metadata:
title: The Garage door is closed
media_class: app
navigateIds:
metadata:
media_class: app
navigateIds:
mode: single
Check the Log and you’re likely to find a warning message that the automation was triggered while it was still busy executing actions from the previous time it was triggered. Single mode ignores a trigger that occurs while the automation is busy.
Consider this scenario:
The automation has played the message at least once and is now counting down the 1-minute delay. During the countdown, the garage door is closed.
That serves to trigger the automation but single mode ignores it because it’s still busy with the countdown. After it completes it, the repeat’s condition is satisfied (i.e. the door is closed) and the automation ends normally. Except it didn’t announce the garage door is closed because that trigger was ignored during the delay’s countdown.
By changing the mode to restart, it will abort the countdown the instant it is triggered again (by the door closing).
Be advised that there is a possibility it can also abort immediately after playing the first message so the second one isn’t played.
Is there a reason why you needed to create a separate media_player.play_media call for each of the two media players?
It seems like the two calls are identical so they can be consolidated into one call. In fact, with a tiny bit of templating, all four calls (two for open, two for closed) can be consolidated into one.
There’s only 2 logs i can see regarding the garage door,
Logger: homeassistant.components.automation.garage_door
Source: helpers/script.py:1783
Integration: Automation (documentation, issues)
First occurred: 20:59:35 (39 occurrences)
Last logged: 21:58:03
garage door : Already running
Logger: pychromecast.controllers
Source: /usr/local/lib/python3.11/site-packages/pychromecast/controllers/media.py:544
First occurred: 19:41:16 (7 occurrences)
Last logged: 19:41:57
Quick Play failed for http://REMOVED/api/tts_proxy/2fd4eaf7d728e2a26697eeb6d56341b0e8514571_en_-_tts.google_en_com.mp3:audio/mpeg({})
The main reason is I’m using the visual editor and I can only pick 1 speaker or all speakers at one time, these have been added from google home i assume basically each speaker and a speaker group I have therefore its adding them a weird way in the yaml editor
is this as simple as,
entity_id: media_player.kitchen_display <<<<adding this line
metadata:
media_class: app
navigateIds:
and then deleting
metadata:
media_class: app
navigateIds:
That’s great thanks, so your code works great, its response time seems to be faster, so it will be the one i’m using
It makes sense to me reading it but changing anything in future may prove hard for me as it doesn’t translate properly into the visual editor
from a learning point of view, I did try and clean up my existing code to put both speakers from one media_player.play_media but as soon as i change anything a red line appears down the left hand side, with no text telling me why, and i cannot save it or go look at the visual editor to see any errors
I did remove a line sequence: as i thought it was now not the case considering I had changed it from 2 media_player.play_media to 1
I then thought it was because of a thumbnail for the kitchen display when the other speaker is just a speaker, but your code has that also with 2 speakers
