I’m trying to turn the lights on when one rings the doorbell.
I use a sonoff RF Bridge with tasmota for this.
While testing with my light remote all worked with received data. but I can only catch the doorbell signal using raw data.
and I think this is where it fails somehow.
I have this in my configuration.yaml
- platform: mqtt
state_topic: "tele/tasmota_EDEBAA/RESULT"
value_template: '{{ value_json.RfRaw.Data.split()[8] }}'
and this in my automations.yaml
- id: 'Doorbell'
alias: DoorBell
description: 'DoorBell'
platform: state
entity_id: sensor.doorbell
to: '0101010101010101010110'
- type: turn_on
device_id: c0e2fd616e529d316d4c45ce610c673e
entity_id: switch.lamp_eenhoek
domain: switch
- service: mqtt.publish
payload: '{"RfRaw":{"Data":"0000"}}'
with my light swicht I could use “value_json.Received.Data”
and all works fine. but since I need to use rfraw. is seems to fail somehow. probably I use split incorrect.
Next to that the mqtt.publish doesn’t do what it is supposed to do. I needs to reset so I can use the trigger again.
Does anyone know a good solution for this?
thank you
