Doorbird Fingerprinter, Nuki 4 and HA
Hello, this is my debut and I apologise if I have to ask a few questions :slight_smile:
The following situation, we have a Doorbird with fingerprinter (D1101FV FINGERPRINT 50). The idea is that the Nuki opens the door when the scanner is used. The Nuki is connected to HA via MQTT and is easy to control.
The scanner can actuate a relay or HTTP signal when activated.
My idea was actually to create a rule that when the relay is activated by the Doorbird, the Nuki opens. Switching the relay directly to HA works and the Nuki opens. However, placing the finger on the scanner does nothing…
Does anyone have an idea or a better way?
THANK YOU!
Hi Timo, any update on your idea? Have you been able to implement it that way? I would like to use a similar setup
This would be nice! Any idea how to implement this?
Same question here…. Is it possible to get this done by the http request of the fingerprint?
