Doorbird integration - can't connect
I’m having trouble integrating a DoorBird camera that I have to open/close a gate at the end of my driveway. I’m hoping someone here can figure out what I’m missing.
I have a local network inside of my home. This network has an Engenius ENH500 point to point wireless bridge plugged into my home network. At the gate (receiving end of the point to point connection), I have an Eero gateway plugged into the Engenius, and then have the DoorBird plugged into the Eero. That Eero is set up as a separate wireless network from my main house.
When I type in the IP address I look up at doorbird.com/checkonline, Home Assistant will not connect to it. I’m guessing that the point to point bridge and separate eero are causing the difficulty, but I can’t figure out what I need to do to let HA find the DoorBird with this setup. Any guidance/advice would be greatly appreciated!
