Double instances after adding Lutron Hub
I recently went back to scratch with Home Assistant and I initially set up my Caseta switches and dimmers by adding the integration (i.e., providing the log-in info for my Lutron account). But HA also Discovered the hub itself, so I added that, and now I have a second set of all of my Caseta devices. This set has none of the names from my Lutron account, so I am wondering if the second set is actually local control and I should use those and disable the first set.
I figured I’d ask here before just charging in, in case someone has some advice.
