Hi all,
being able to do this would really help me declutter some of my light automations:
Within the automation (in Switch Manager, but that shouldn’t make a difference) I have a variable “last_pressed_id” that references a helper wall_switch_last_pressed. The helper then contains the name of the light which was turned on/off with the most recent button press. So it would be:
variable “last_pressed_id”: input_text.wall_switch_last_pressed
helper input_text.wall_switch_last_pressed: light.kitchen_ceiling
Now I want to use
action: light.turn_on
metadata: {}
transition: 1
brightness_step_pct: "-{{ data.variables.step_size_step }}"
kelvin: "{{ states('input_select.kitchen_ceiling_up_color_temp_helper') | int(0) }}"
entity_id: "{{ data.variables.last_pressed_id }}"
But obviously (?), data.variables.last_pressed_id does not reference “two levels down” to “light.kitchen_ceiling”. Is there a way this can be done?
Thanks so much in advance.
