I’m trying to download WiFi signal time series data in Home Assistant. I note there is a download data tab and a time range that you can adjust to view it in the web portal.
However, when I hit download, it does not give me the latest data for the time range. It stops 1-2 days behind even though I can see the latest raw data in the portal. Is there an API or a function command option etc that I can use to ensure that I get the latest data?
Thanks.
