I got a D1 mini with a L298N to control a motor to go both directions. It was successful. Then I tried to add an INA219 to monitor the current going through the motor, in order to detect stalling.
First I set the update_interval of this sensor to be 500ms. From home assistant I can see the normal running current of the motor is about 200ma. And the when I tried to manually stall it, the current changes drastically, which is exactly what I expected. So far so good.
Next I tried to add the following filters to the sensor:
filters:
- or:
- throttle: 10s # only send an update every 10 seconds
- delta: 0.05 # unless current has changed by more than 0.05a
And that brings a problem, once the current changes drastically, the sensor value returns to 0 and refused to update no matter how long you wait.
Below is the sensor history that illustrate the problem. The left segment is recorded without the filters defined. I tried to stall the motor multiple times, result in multiple spikes. The right segment is recorded with the filters in place. Once the current spiked, it just refused to update it. The motor is still running, but the current value stuck at 0, forever.
What might be the problem? Thanks for helping out.
My yaml
esphome:
friendly_name: d1mini
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "D1Mini Fallback Hotspot"
password: ""
captive_portal:
# static const uint8_t D0 = 16;
# static const uint8_t D1 = 5;
# static const uint8_t D2 = 4;
# static const uint8_t D3 = 0;
# static const uint8_t D4 = 2;
# static const uint8_t D5 = 14;
# static const uint8_t D6 = 12;
# static const uint8_t D7 = 13;
# static const uint8_t D8 = 15;
# static const uint8_t RX = 3;
# static const uint8_t TX = 1;
output:
- platform: gpio
pin: GPIO15 # D8
- platform: gpio
pin: GPIO13 # D7
# Example configuration entry
i2c:
- id: bus_a
sda: GPIO4 # D2
scl: GPIO5 # D1
scan: true
- platform: ina219
i2c_id: bus_a
address: 0x40
shunt_resistance: 0.1 ohm
current:
filters:
- or:
# power:
# name: "INA219 Power"
# id: ina_power
max_voltage: 32.0V
max_current: 3.2A
update_interval: 500ms
switch:
- platform: output
output: pin_d8
- platform: output
output: pin_d7
cover:
optimistic: True
open_action:
- switch.turn_off: switch1
- switch.turn_on: switch2
- delay: 30s
- switch.turn_off: switch2
close_action:
- switch.turn_on: switch1
- delay: 90s
stop_action:
