I have this configured for monthly but it reset early this morning and I have been running this for two days.
Do I have it configured correctly?
state_class: total_increasing
status: collecting
last_period: "0"
last_valid_state: "0.850631366872714"
last_reset: "2026-08-23T01:13:48.847680+00:00"
next_reset: "2026-09-01T00:00:00-07:00"
unit_of_measurement: gal
device_class: water
friendly_name: Water Monthly Usage
Impossible to say. Share the utility meter configuration. Not its attributes.
I found a work around using Gemini.
You shouldn’t need a “work-around”. Share the solution you are using, and your utility meter config. Very likely we will have better advice for you.
What I mean is that it is working
And what I mean is that very likely what Gemini has provided you with is not the best way to do it.
I can’t figure out a way to share the configuration in utility meter.
