Ds-kv6124-wbe1
Hello, I bought the DS-KV6124-WBE1 model but it won't connect via MQTT. I've tried both add-ons and there's no response from the video intercom. Any solutions?
What is it?
How have you tried to connect it / What Apps did you try?
Are you running HAOS?
How to help us help you - or How to ask a good question.
I've tried it with Home Assistant, but I can't get the integration to connect.
Did you try updating the speaker firmware so the red wire is energized.
I'm sorry, that is completely made up. Sir we have no context and have no idea what you are doing. If you are not using Home Assistant at all then you will have better response some place where they know the device you are using and the software you are using with it.
The posts here need to be focused around Home Assistant and things using it.
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/
