I’m currently running DSMR Reader on a separate Linux VM.
I’d like to port it to this great DSMR add-on in Home Assistant.
This will save me from having to maintain a Linux VM.
Has anyone ever had issues with the USB port/path suddenly changing to HA?
What do you mean with “suddenly changing”?
In Linux (and home assistant) try to use “/dev/serial/by-id/” and not device paths like /dev/ttyUSB0
The serial/by-id paths stay the same as long as you do not change the hardware.
About 2 months ago I have bought this dsmr smart meter, went through the setup step by step as provided without any issues. And got it working in home assistant flawlessly.
However, after 1 hour it stops. Every time. I’ve searched different forums, one suggestion was to use usb-power instead of only through the p1, didn’t change anything. The second top-advice was to set the entity-update to lower/higher intervals, no effect… Updated to the latest firmware, no effect.
My guess is theres a bigger error in my system, perhaps the database or idk… I am not an IT specialist lol, your help would be appreciated!
In short: it reads both electricity and gas in HA for one hour after plugged in and then stops.
The log from homeassistant on its error:
Logger: homeassistant.components.dsmr
Bron: components/dsmr/sensor.py:808
integratie: DSMR Smart Meter (documentatie, problemen)
Eerst voorgekomen: 10:22:52 (1115 gebeurtenissen)
Laatst gelogd: 21:16:14
Error connecting to DSMR
File "/usr/src/homeassistant/homeassistant/components/dsmr/sensor.py", line 808, in connect_and_reconnect
transport, protocol = await hass.loop.create_task(reader_factory())
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1171, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1146, in create_connection
sock = await self._connect_sock(
exceptions, addrinfo, laddr_infos)
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1045, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 641, in sock_connect
return await fut
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 681, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.0.237', 23)
After the error occurs please check if the Homewizard app can get a readout. If it fails contact the Homewizard helpdesk.
If the Homewizard app functions normally, Check the network route between the P1 meter ND your home assistant installation. What wifi access point are you using, what switches, is the cabling OK?
Forgot to mention I’ve got the smartgateways “Slimme Meter WiFi Gateway” and not from homewizard. Using it with the original cable that came with it.
I have unify access points but its not on there (all current connected clients are defined/known). Theres one netgear switch on the network, setup only to connect all rooms/wallsockets.
After one hour I cannot access the smart meter gateway anymore through the browser. When reconnect (after a minute) it restarts and connected to my wifi again:
Gateway type NL - DSMR4+5
Mac address xx_xx_xx_xx_xx_xx (edited before posting)
Ip address 192.168.0.237
Startup time 2025-12-29T12:33:40Z
Firmware running 2025070304
Firmware available 2025070304
License activated YES
Number of reboots 22
WiFi SSID telenet-9391775
WiFi channel 1
WiFi signal strength -30
WiFi reconnects 0
WiFi last connection error
Internet connection OK
MQTT server
MQTT status Not configured
MQTT (re)connects 0
MQTT (re)connect time
Secondary port found No
Forwarding mode Not available
Remote Gateway
Remote Gateway status Disconnected
Telegrams received 32
Telegrams with errors 32
HomeAssistant log: (WARNING)
Logger: dsmr_parser.clients.protocol
Bron: runner.py:289
Eerst voorgekomen: 28 december 2025 om 16:10:34 (6 gebeurtenissen)
Laatst gelogd: 11:46:19
keep-alive check failed
use a dedicated power supply with a rating of 5V / 1A written on the case. I read you have tried a power supply already and I wonder if you have used a good power supply
Use a different 2.4 ghz wifi channel
Move your gateway to a different place (just a few centimeters)
after the meter disappears from the network look at the LED:
Led betekenis (alleen gateway zonder display, de gateway met display toont de status op het display)
Het rode ledje brandt indien de gateway is voorzien van stroom.
Het blauwe ledje kan op verschillende manieren gaan branden of knipperen.
BLAUWE LED – UIT: de gateway is niet verbonden met wifi of de wifi portal is opgeroepen door de knop kort in te drukken. Verbind met het SSID “Smart Gateways P1 READER” en configureer de gateway.
BLAUWE LED – ALTIJD AAN: de gateway is verbonden met het wifi netwerk maar heeft nog geen data ontvangen van de slimme meter.
BLAUWE LED – KNIPPERT LANGZAAM: de gateway ontvangt data van de meter (normale situatie)
BLAUWE LED – KNIPPERT SNEL: er is een firmware update beschikbaar. De update kan via het firmware menu op de webportal worden geïnstalleerd.
