DSMR slimme meter - ability to read more than ONE meter
Would it please be possible to add the ability to have more than one Electric utility meter connected with the P1 port to home assistant.
I have two meters (Belgium, Fluvius) one for “single use power” and one for “pure night” power (the pure power is for accumulation heating)
when I connect both meters it will only give information for the first connected one,
when I change the USB port I get readings from the other meter, but they overwrite the information from the previous connected meter.
I would like to be able to name the meters and link them to specific USB ports and if possible would like to get sensor readings from both meters with slightly different names (maybey add the meter name to the sensor)
Would anyone be able to do this ?
https://www.home-assistant.io/integrations/dsmr/
thank you in advance,
Hans
