Good morning,
I have 16 room thermostats
this is a configuration of 1 of 16
- platform: dualmode_generic
unique_id: climate.Armadio
away_temp:
value_template:"{{ state_attr('cliamate.Casa','temperature') }}"
heater: light.sth001
cooler: light.sth001
target_sensor: sensor.th_001_temperature
reverse_cycle: cooler, heater
enable_heat_cool: True
min_temp: 16
max_temp: 30
cold_tolerance: 0.5
hot_tolerance: 0.5
min_cycle_duration:
minutes: 1
and I created 1 master thermostat.
unique_id: climate.Casa
heater: switch.esphome_web_234580_estateon_inverno_off
cooler: switch.esphome_web_234580_estateon_inverno_off
target_sensor: sensor.media_interna_degc
min_temp: 16
max_temp: 30
cold_tolerance: 0.5
hot_tolerance: 0.5
min_cycle_duration:
minutes: 1
I need to make the desired temperature of the Generic thermostat the away temperature of the secondary thermostats. to set all basic thermostat at the master set the other 16
I also need to check the heating on two outlets
heater: light.sth001,light.sth001ta
