Hey,
i can’t access home assistant from outside since duckdns failed this morning. Over the local IP in the network it works but no longer over the duckdns address.
According to the homeassistant logs everything is started and no errors are displayed.
when i try to call the duckdns address it just loads forever.
“Hmmm…unfortunately this page is not reachable The answer from flex-home.duckdns.org took too long”
The last month, I have a lot of problems with DuckDNS. Sometimes fail for 5-10 minutes. If I access by external IP works fine, but by DuckDNS don’t. I think is problem of DuckDNS server.
