My problem is, i couldn’t get ducndns to work on my edge router with just port-forwarding so i followed instructions on the DuckDNS website and set DDNS on my edgerouter.
Now i face the issue where i have to manually ForceUpdate ddns on edgerouter in order to get access to hassio. It works for couple of minutes and then it dies again.
I have extensive experience in networking and also the EdgeRouter and I’d surely like to help you out.
I think this would need a closer look and won’t be handy to discuss on the forums. I think a chat session would be most convenient… Maybe add me on FB (my full name is on my profile info) and send me a message?
I’m facing a similar problem. Everything was fine until I added an edgerouter X, put my isp fibre modem/router into bridge mode and now I cannot resurrect my ssl access to HA.
Did you end up solving the problem? Can you now access home assistant with a duckdns URL on the edgerouter? Do you mind sharing your config on the edgerouter? Thanks.
