I’m sure there is a step I’m missing so I’m sorry if this turns out to be obvious!
was trying the new way of installing DuckDNS/LetEncrypt on a freshly installed Hassbian instant.
Followed the simple steps except running as Homeassistant (just not comfortable giving that user full sudo), everything installed correctly, and from the look of it, it was all good to go.
Restart homeassistant, go to mydomain.duckdns.org–> Problem Loading Page
Restart RPi, go to domain --> Problem Loading Page
Check Homeassistant log --> All components loaded, HTTP component loaded fine (not surprised)
go to router and port forward 8123 >8123 --> Problem loading Page
Used to run All-in-one homeassistant installation, had letsEncrypt and Duckdns running solid since Dec 2016. So I’m sure something has changed since the last time I tried to fresh install.
So maybe its that I didn’t run as Homeassistant, but I somehow doubt that.
Any guidance would be awesome, thanks in advance
