Hi all, new here but I’d read/searched any so on, I am thinking I’ve only one alternative left after this - if it doesn’t work so.
Current config:
HA Yellow/CM5/NVM/PoE - all working/installed fine.
- Static IP locally
- DHCP from my Firewalla
- Port forwarding complete/DuckDNS working - can navigate internally to it or externally and all working good with a Lets Encrypt cert.
- IPv6 disabled on Firewalla and HA Yellow
Issues
Cert mismatch on the HA iOS App when I use http S ://homeassistant.lan:8123. I know this is because the Lets Encrypt doesn’t have my LAN address of the HA - hence mismatch but how can I resolve this?
1.1. I have installed Nginx Proxy Manager/reinstalled with a full config clear (cache clear/different browser/in private) to try and manage the redirection but it doesn’t seem to work. -
HACS Alexa plugin - I know it might not be fully supported/wrong place to post but after entering the correct config and HA > Amazon.co.uk the redirection back to the HA (through the duckdns (which is publicly accessible)) gives me a 500 error.
When in Settings > System > Network
- hostname = homeassistant.lan - pingable from any machine on my lan
- HA URL = http S mysubdomain.duckdns.org:8123
- Local network https S homeassistant.lan:8123
Current status is just DuckDNS/Lets Encrypt configured and working, but I’d really like to be able to access HA from the mobile apps locally & sort this Alexa HACS issue.
Logs below from HA after the failure of issue 2
2025-01-19 14:01:20.288 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.13/site-packages/httpx/_transports/default.py", line 72, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.13/site-packages/httpx/_transports/default.py", line 377, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.13/site-packages/httpcore/_async/connection_pool.py", line 216, in handle_async_request
raise exc from None
File "/usr/local/lib/python3.13/site-packages/httpcore/_async/connection_pool.py", line 196, in handle_async_request
response = await connection.handle_async_request(
pool_request.request
File "/usr/local/lib/python3.13/site-packages/httpcore/_async/connection.py", line 101, in handle_async_request
return await self._connection.handle_async_request(request)
File "/usr/local/lib/python3.13/site-packages/httpcore/_async/http11.py", line 143, in handle_async_request
raise exc
File "/usr/local/lib/python3.13/site-packages/httpcore/_async/http11.py", line 113, in handle_async_request
) = await self._receive_response_headers(**kwargs)
File "/usr/local/lib/python3.13/site-packages/httpcore/_async/http11.py", line 186, in _receive_response_headers
event = await self._receive_event(timeout=timeout)
File "/usr/local/lib/python3.13/site-packages/httpcore/_async/http11.py", line 224, in _receive_event
data = await self._network_stream.read(
self.READ_NUM_BYTES, timeout=timeout
File "/usr/local/lib/python3.13/site-packages/httpcore/_backends/anyio.py", line 32, in read
with map_exceptions(exc_map):
File "/usr/local/lib/python3.13/contextlib.py", line 162, in __exit__
self.gen.throw(value)
File "/usr/local/lib/python3.13/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
raise to_exc(exc) from exc
httpcore.ReadTimeout
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
return await handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/config/custom_components/alexa_media/config_flow.py", line 1066, in wrapped
return await cls.handler(request, **kwargs)
File "/usr/local/lib/python3.13/site-packages/authcaptureproxy/auth_capture_proxy.py", line 442, in all_handler
resp = await getattr(self.session, method)(
site, data=data, headers=headers, follow_redirects=True
File "/usr/local/lib/python3.13/site-packages/httpx/_client.py", line 1905, in post
return await self.request(
...<13 lines>...
File "/usr/local/lib/python3.13/site-packages/httpx/_client.py", line 1585, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.13/site-packages/httpx/_client.py", line 1674, in send
response = await self._send_handling_auth(
...<4 lines>...
File "/usr/local/lib/python3.13/site-packages/httpx/_client.py", line 1702, in _send_handling_auth
response = await self._send_handling_redirects(
...<3 lines>...
File "/usr/local/lib/python3.13/site-packages/httpx/_client.py", line 1739, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.13/site-packages/httpx/_client.py", line 1776, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.13/site-packages/httpx/_transports/default.py", line 376, in handle_async_request
with map_httpcore_exceptions():
File "/usr/local/lib/python3.13/site-packages/httpx/_transports/default.py", line 89, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ReadTimeout
