Hello!
A few days ago the ISP provider gaves me a external ip and ability to forward ports, So i did it, I forwared a port 8123. After this i installed a duckdns addon and this is my config:
"lets_encrypt": {
"accept_terms": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
"token": "xxxxxxxxxxxxxxxxxxxxxxxxxxxx",
"domains": [
"nameofdomain.duckdns.org"
"seconds": 300
In configuration.yaml I got:
http:
base_url: https://nameofdomain.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
When i connect to hassio by my android phone not connected to local wifi everything is working fine. The problem is when i use the pc connected to the same lan/wifi. Site is not loading at all. When i connect to local ip https://192.168.100.12:8123 it is working. I could use this kind of adress on my pc but i need to configure another addons webui addresses aswell, so it is a problem. If i define it like 192.168… it wont work when i connect by adress https://mydomain.duckds.org:8123. What i have to do? How to make it work by domain name on pc connected to lan aswell?
