Duckdns - Warnings
I’m getting warning in my logs file for my HACS Duckdns, I’ve not seen this before and am unsure why this is happening?
Its triggering every 5 mins
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[07:50:11] WARNING:
[07:50:12] INFO: Renew certificate for domains: **********.duckdns.org and aliases:
Processing **********.duckdns.org
 + Checking domain name(s) of existing cert... unchanged.
 + Checking expire date of existing cert...
 + Valid till Apr  7 04:14:30 2024 GMT (Longer than 30 days). Skipping renew!
[07:55:14] WARNING:
[08:00:14] WARNING:
[08:05:14] WARNING:
[08:10:14] WARNING:
[08:15:14] WARNING:
[08:20:14] WARNING:
[08:25:14] WARNING:
[08:30:14] WARNING:
[08:35:14] WARNING:
[08:40:14] WARNING:
[08:45:14] WARNING:
[08:50:15] WARNING:
[08:55:15] WARNING:
[09:00:15] WARNING:
[09:05:15] WARNING:
Any ideas?
I just set up DuckDNS again on a different server and encountered the same problem. The post is old and presumably solved, but in my case I didn’t realise there was a space at the start of the token. Viewing the YAML config made this obvious and removing the space stopped the warning.
