so after you fix this in the Duck DNS addon, do you have to add anything to the config? Every time I add the duckdns information to the config, it just spins the circle after i enter my api password,
I ahve mine structured correctly like yours, and I am still getting a “KO” error.
I had the same problem. The sample text on many of these configuration options have simple text such as null, but when you replace that text, you’re supposed to know you have to add quotes around the text. Still trying to figure out all these syntax rules!
