Duplicate Espurna switches in HA
I have flashed Sonoff basics with Espurna and configured to HomeAssistant. But the Switches are appearing duplicated in the control panel, with only one of the two active. I have also have 2 Tasmota sonoffs which appear correctly. Has anyone got a suggestion as to why the sonoffs are duplicated.
Perhaps one is auto discovered, and the other is your configuration. If the device is auto discovered you don’t need to put it in the yaml file too.
Hi thanks for your suggestion. I have tried deleting the .yaml entry but the switch will then not latch. Any more suggestion,please?
Not really I am afraid. I was just looking at espurna the other day and noticed it had HA discovery support and thought I might know why you are getting double entries.
Perhaps some logs or something might help?
Hi thanks for the suggestion anyway.I will persevere.If I get a solution,I will post it.
I have found that by discovery being deselected in Hass Tab and Alexa Integration being unchecked, duplicates do not appear.
