Duplicate SRNE Inverter in Home Assistant via Solar Assistant (MQTT)
Hi, I’ve integrated my SRNE inverter with Home Assistant using Solar Assistant via MQTT, following the instructions on the official Solar Assistant website. Everything works fine, except that the inverter shows up twice in Home Assistant with the same data.
I’ve tried manually removing the duplicate entity, but it reappears after a while. Does anyone know how to prevent this duplication or how to fix it permanently?
Thanks in advance for your help.
