DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
I’m not 100%, I think i’m using a persons addon. Here is what I have.
persons.yaml
persons:
  - name: Mike
    track: person.mike
    picture_path: 'images/persons/mike.jpg'
    addons:
      - name: Mobile info
        icon: fas:mobile
        path: 'dwains-theme/addons/persons/mike/page.yaml'
page.yaml
- type: custom:mod-card
  style: |
    ha-card {
      padding: 0px 8px 20px 8px;
  card:
    type: vertical-stack
    cards:
      - type: horizontal-stack
        cards:
          - template: room_device
            type: custom:button-card
            entity: sensor.mikes_phone_battery_level
            show_last_changed: false
            entity: sensor.mikes_phone_battery_state
            entity: sensor.mikes_phone_wifi
            entity: sensor.mikes_phone_location
Ok. I switched from addon to page_entities. Thanks for the help and the awesome theme.
Mike
Anyone know what i’m doing wrong to get the below results?
This is a fresh install of the theme, on HA 0.106.4
I can see in your config files that you use custom:cover-slider-card, what card is that? I cant find anything about it when I serch on the web?
On a side note (not sure I want to do this yet) but is there a way to remove the map all together from the persons section?
From version 1.2.0 and on, you don’t need an addon for the person page like you want.
You can do it with persons.yaml like this:
persons:
  - name: Dwain
    track: person.dwain
    picture_path: 'images/persons/dwain.jpg'
    #show_map: 'false' #Map is enabled by default, uncomment this line to disable the map
    page_entities:
      columns: 2 #optional number of columns I recomend 1, 2 or 3 (default is 2)
      entities:
        - entity: sensor.mikes_phone_battery_level
        - entity: sensor.mikes_phone_battery_state
        - entity: sensor.mikes_phone_wifi
        - entity: sensor.mikes_phone_location
Try updating your button card plugin in HACS or re-install it.
It’s a custom card I made myself its located in www/dwains-theme/plugins not in HACS
How did you make the Battery, Charging, Wifi, Location cards smaller?
Pretty sure it’s 4 columns vs 2. The cards are smaller to fit 4 across the row.
add show_map: 'false' to your persons.yaml
I should rtfm, I see it in the docs now.
Installed the new Coronavirus Integration and used the Dynamic Page for this.
Can you sbare you code? Nice job
Here you go,
I installed the Coronavirus Integration for U.S. and Worldwide. Put the code below in config\dwains-theme\addons\dynamic_page\hello-dynamic-page\page.yaml file. For the icon on the dock I used mdi:scull-crossbones in my config\dwains-theme\config\dyanmic_page.yaml
# dwains_theme
  style: |
    ha-card {
  card:
    cards:
      - type: picture
        image: 'https://www.dshs.state.tx.us/uploadedImages/Content/Consumer_and_External_Affairs/coronavirus/banner.png'
        tap_action:
          action: url
          url_path: 'https://www.arcgis.com/apps/opsdashboard/index.html#/bda7594740fd40299423467b48e9ecf6'
      - type: entities
              - type: entities
        style: |
          ha-card {
            background-color: var(--dwains-theme-primary);
            border-radius: 100px
            font-weight: bold;
            font-size: 14px;
            overflow: hidden;
            width: 100%;
            height: 75%;
            margin: 0 auto;
            padding-top: 0px;
        title: United States Cases
        show_header_toggle: false
        entities:
          - entity: sensor.us_confirmed
            icon: 'mdi:emoticon-neutral-outline'
          - entity: sensor.us_current
            icon: 'mdi:emoticon-frown-outline'
          - entity: sensor.us_recovered
            icon: 'mdi:emoticon-happy-outline'
          - entity: sensor.us_deaths
            icon: 'mdi:emoticon-dead-outline'
      - type: entities
              - type: entities
        style: |
          ha-card {
            font-weight: bold;
            font-size: 14px;
            overflow: hidden;
            width: 100%;
            height: 75%;
            margin: 0 auto;
            padding-top: 0px;
        title: World Wide Cases
        entities:
          - entity: sensor.worldwide_confirmed
          - entity: sensor.worldwide_current
          - entity: sensor.worldwide_recovered
          - entity: sensor.worldwide_deaths
I also typed a complete example for you :sweat_smile: :rofl: 5 posts above your post… Dwains Dashboard - 1 CLICK install Dashboard for desktop, tablet and mobile - V3.1.0 - #417 by dwains
Lol, sorry I didn’t notice this line in your example. I thought you were just answering the part about moving the items up above the map. Again, I should read more thoroughly.
#show_map: ‘false’ #Map is enabled by default, uncomment this line to disable the map
Yeah haha no problem. A lot of things are in the documentation so, but you are not the only one asking questions which are in the documentation :stuck_out_tongue:
Thank you!!
Hi this is excellent I just had a few issues implementing the page.yaml file you have shown here.
I needed to remove the second
“- type: entities” in both cases in the yaml.
Thank you again
