Trying to figure this out after scouring the forums.
I have an ESP8266 that I have programmed using this how-to GarHAge
Here is my configuration.yaml
cover:
- platform: mqtt
name: "Garage Door Test"
unique_id: "GarageDoor"
state_topic: "garage/door/1/status"
command_topic: "garage/door/1/action"
availability_topic: "GarHAge/availability"
qos: 0
optimistic: false
retain: false
payload_open: "OPEN"
payload_close: "CLOSE"
payload_stop: "STATE"
state_open: "open"
state_closed: "closed"
payload_available: "online"
payload_not_available: "offline"
I have also added this to customize.yaml
cover.garage_door_test:
device_class: garage
Everything is working great including Amazon Echo seeing it as a garage door and allowing me to enable a security code to open using Alexa.
But the only problem is the Button Card Configuration card.
When the cover.garage_door_test is closed it shows the correct icon, but when it is open it only charges the icons color to yellow and does not show the HASS:garage-open icon. As you can see in the example.
The top Garage Door is a MYQ and I want to replace it.
What can i do to fix this? I thought changing the device_class to garage would do that but that did not work.
Thanks for any help.
