Hi all,
I want to dynamically update the icon of a input_number object, is this possible?
It does not have the icon_template property.
Many thanks in advance!
Hi all,
I don’t think this is possible through normal conventions. You’d need to make a custom panel or use a template sensor as your changing icon:
Thanks, I will try it this evening
Hi all,
Any update on this, I was making a new integration today and hit the same issue again.
Was unable to solve it in a simple way last time.
Is it possible to dynamically update the icon of a input_number object.
I noticed it only has the icon property and not the icon_template property.
Could this be added to this object? Where can I put this request?
Would be great to have this so the object would be more in line with most other objects in HA
You can do it with the Custom UI, assuming you are using the old interface. I was incorrect with linking custom panel in my previous post.
Thanks, I will read up on the custom UI feature
