Hey everyone, I’m racking my brain here. Maybe someone can point me in the right direction. I have a plant sensor (very basic), but I want an attribute that dynamically points to the right input_datetime using the plant_name attribute (thats the naming convention for the datetime helpers).
- sensor:
- name: "Avocado"
unique_id: 7604a08d-1f22-49b8-98e2-e0c9b35a2308
unit_of_measurement: "Days"
icon: mdi:sprout
state: >
{% set dt = this.attributes.last_watered | default(0)
| as_datetime | as_local %}
{{ (dt.date() - now().date()).days | abs }}
attributes:
plant_name: "Persea Americana"
watering_interval: "7"
last_watered: >
"{{ states('input_datetime.' ~ this.attributes.plant_name.replace(' ', '_') | lower) }}"
My sensor goes unavailable as soon as I do this. When I change my sensor as follows:
- sensor:
- name: "Avocado"
icon: mdi:sprout
state: >
attributes:
test: "{{ states('input_datetime.' ~ this.attributes.plant_name.replace(' ', '_') | lower) }}"
last_watered: "2025-05-13"
You can see below the output values of “test” and “last_watered” are identical. Still it won’t work when I use the template in the last_watered attribute.
Thanks for taking your time in advance.
