I have a displaying Problem with my E ink display. I got it running and it shows the values from HA that i want. But the displaying quality is wierd. the text is very grizzly and not really black. but on the other hand some lines are perfekt black.
And sometimes if i leave it unplugged for some time all is black in the beginning and will fade out suddenly after like a few refreshes.
I got this esp32 with display combo:Amazon.de
Maybe someone has a good advise on what to do
My Code:
esphome:
friendly_name: E-Paper Dashboard
on_boot:
then:
- switch.turn_on: display_power
- script.execute: update_screen
on_shutdown:
then:
- switch.turn_off: display_power
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "my password"
encryption:
key: "my key"
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Display Fallback Hotspot"
password: "TvLUBQZ1sCut"
switch:
- platform: gpio
pin: GPIO32 #display power enable pin
internal: true
button:
- platform: restart
name: "Dashboard - Restart"
name: "Dashboard - Refresh Screen"
entity_category: config
on_press:
script:
- id: update_screen
then:
- component.update: screen
# Include custom fonts
font:
- file: 'fonts/GothamRnd-Book.ttf'
- file: 'fonts/GothamRnd-Bold.ttf'
# glyphs: [' ', '-', '°', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'C']
# glyphs: ['W', 'E', 'A', 'T', 'H', 'R', 'L', 'I', 'N', ' ']
# glyphs: [' ', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'M', 'I', 'N']
# glyphs: [' ', '-', '°', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'C', 'M', 'I', 'N']
# Include Material Design Icons font
# Thanks to https://community.home-assistant.io/t/display-materialdesign-icons-on-esphome-attached-to-screen/199790/16
- file: 'fonts/materialdesignicons-webfont.ttf'
glyphs: &mdi-weather-glyphs
- "\U000F0590" # mdi-weather-cloudy
- "\U000F0F2F" # mdi-weather-cloudy-alert
- "\U000F0E6E" # mdi-weather-cloudy-arrow-right
- "\U000F0591" # mdi-weather-fog
- "\U000F0592" # mdi-weather-hail
- "\U000F0F30" # mdi-weather-hazy
- "\U000F0898" # mdi-weather-hurricane
- "\U000F0593" # mdi-weather-lightning
- "\U000F067E" # mdi-weather-lightning-rainy
- "\U000F0594" # mdi-weather-clear-night
- "\U000F0F31" # mdi-weather-night-partly-cloudy
- "\U000F0595" # mdi-weather-partly-cloudy
- "\U000F0F32" # mdi-weather-partly-lightning
- "\U000F0F33" # mdi-weather-partly-rainy
- "\U000F0F34" # mdi-weather-partly-snowy
- "\U000F0F35" # mdi-weather-partly-snowy-rainy
- "\U000F0596" # mdi-weather-pouring
- "\U000F0597" # mdi-weather-rainy
- "\U000F0598" # mdi-weather-snowy
- "\U000F0F36" # mdi-weather-snowy-heavy
- "\U000F067F" # mdi-weather-snowy-rainy
- "\U000F0599" # mdi-weather-sunny
- "\U000F0F37" # mdi-weather-sunny-alert
- "\U000F14E4" # mdi-weather-sunny-off
- "\U000F059A" # mdi-weather-sunset
- "\U000F059B" # mdi-weather-sunset-down
- "\U000F059C" # mdi-weather-sunset-up
- "\U000F0F38" # mdi-weather-tornado
- "\U000F059D" # mdi-weather-windy
- "\U000F059E" # mdi-weather-windy-variant
- "\U000F10AF" # mdi-door-closed-lock
- "\U000F081C" # mdi-door-open
- "\U000F12A3" # mdi battery 100
- "\U000F12A2" # mdi battery 60
- "\U000F12A1" # mdi battery 30
- "\U000F008E" # mdi battery 0
- "\U000F1904" # mdi home-lightning-bolt-outline
- "\U000F1A73" # mdi solar-power-variant
- "\U000F192C" # mdi transmission-tower-import
- "\U000F192D" # mdi transmission-tower-export
- "\U000F0734" # mdi arrow right
- "\U000F0731" # mdi arrow left
- "\U000F0D3E" # mdi transmission
glyphs: *mdi-weather-glyphs
# Define colors
# This design is white on black so this is necessary.
color:
- id: color_bg
white: 0%
- id: color_text
white: 100%
# E paper Display
# Pins für Waveshare ePaper ESP Board
spi:
clk_pin: GPIO13
mosi_pin: GPIO14
display:
- platform: waveshare_epaper
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin:
number: GPIO25
inverted: false
reset_pin: GPIO26
reset_duration: 500ms
model: 7.50in-bv3
update_interval: 60s
rotation: 0°
lambda: |-
// Map weather states to MDI characters.
std::map<std::string, std::string> weather_icon_map
{"cloudy", "\U000F0590"},
{"cloudy-alert", "\U000F0F2F"},
{"cloudy-arrow-right", "\U000F0E6E"},
{"fog", "\U000F0591"},
{"hail", "\U000F0592"},
{"hazy", "\U000F0F30"},
{"hurricane", "\U000F0898"},
{"lightning", "\U000F0593"},
{"lightning-rainy", "\U000F067E"},
{"clear-night", "\U000F0594"},
{"night-partly-cloudy", "U000F0F31"},
{"partlycloudy", "\U000F0595"},
{"partly-lightning", "\U000F0F32"},
{"partly-rainy", "\U000F0F33"},
{"partly-snowy", "\U000F0F34"},
{"partly-snowy-rainy", "\U000F0F35"},
{"pouring", "\U000F0596"},
{"rainy", "\U000F0597"},
{"snowy", "\U000F0598"},
{"snowy-heavy", "\U000F0F36"},
{"snowy-rainy", "\U000F067F"},
{"sunny", "\U000F0599"},
{"sunny-alert", "\U000F0F37"},
{"sunny-off", "\U000F14E4"},
{"sunset", "\U000F059A"},
{"sunset-down", "\U000F059B"},
{"sunset-up", "\U000F059C"},
{"tornado", "\U000F0F38"},
{"windy", "\U000F059D"},
{"windy-variant", "\U000F059E"},
// Map door states to MDI characters.
std::map<std::string, std::string> door_map
{"locked", "\U000F10AF"},
{"unlocked", "\U000F081C"},
it.line(400, 0, 400, 480);
it.line(0,240,800,240);
it.rectangle(0,0,330,150);
it.rectangle(350,0,800, 140);
//Date and Time
it.strftime(165, 30, id(small), color_text,TextAlign::CENTER, "%d.%m.%Y", id(homeassistant_time).now());
it.strftime(165, 100, id(big), color_text,TextAlign::CENTER, "%H:%M", id(homeassistant_time).now());
//PV Anlage
float ladezustand = id(battery_level).state;
float netzbezug = id(solarnet_leistung_netzbezug).state;
float netzeinspeisung = id(solarnet_leistung_netzeinspeisung).state;
float pv_leistung = id(solarnet_pv_leistung).state;
float verbrauch = id(solarnet_leistung_verbrauch).state;
std::string icon = "";
std::string icon_pv = "\U000F1A73"; // mdi-solar-power-variant
std::string icon_netzeinspeisung = "\U000F192D"; // mdi-transmission-tower-export
std::string icon_netzbezug = "\U000F192C"; // mdi-transmission-tower-import
std::string icon_verbrauch = "\U000F1904"; // mdi-home-lightning-bolt-outline
std::string icon_arrow_right = "\U000F0734"; // mdi arrow right
std::string icon_arrow_left = "\U000F0731"; // mdi arrow left
std::string icon_transmission = "\U000F0D3E"; // transmission
// PV-Leistung
it.printf(390, 45, id(font_mdi_medium),TextAlign::CENTER, "%s", icon_pv.c_str());
if (pv_leistung <1000){
it.printf(390, 120, id(small),TextAlign::CENTER, "%.0fW", pv_leistung);
}else{
pv_leistung=pv_leistung/1000;
it.printf(390, 120, id(small),TextAlign::CENTER, "%.2fkW", pv_leistung);
// Verbrauch
it.printf(510, 45, id(font_mdi_medium),TextAlign::CENTER, "%s", icon_verbrauch.c_str());
if (verbrauch <1000){
it.printf(510, 120, id(small),TextAlign::CENTER, "%.0fW", verbrauch);
}else{
verbrauch=verbrauch/1000;
it.printf(510, 120, id(small),TextAlign::CENTER, "%.2fkW", verbrauch);
// Netzbezug/Netzeinspeisung
it.printf(640, 45, id(font_mdi_medium),TextAlign::CENTER, "%s", icon_transmission.c_str());
if ((netzbezug-netzeinspeisung)>0){
it.printf(575, 45, id(font_mdi_medium),TextAlign::CENTER, "%s", icon_arrow_left.c_str());
if(netzbezug<1000){
it.printf(645, 120, id(small),TextAlign::CENTER, "%.0fW", netzbezug);
}else{
netzbezug = netzbezug /1000;
it.printf(645, 120, id(small),TextAlign::CENTER, "%.2fkW", netzbezug);
}else{
it.printf(575, 45, id(font_mdi_medium),TextAlign::CENTER, "%s", icon_arrow_right.c_str());
if(netzeinspeisung<1000){
it.printf(645, 120, id(small),TextAlign::CENTER, "%.0fW", netzeinspeisung);
}else{
netzeinspeisung = netzeinspeisung/1000;
it.printf(645, 120, id(small),TextAlign::CENTER, "%.2fkW", netzeinspeisung);
// Ladezustand prüfen und entsprechendes Icon setzen
if (ladezustand > 75) {
icon = "\U000F12A3"; // mdi battery 100
} else if (ladezustand > 45) {
icon = "\U000F12A2"; // mdi battery 60
} else if (ladezustand > 20) {
icon = "\U000F12A1"; // mdi battery 30
} else {
icon = "\U000F008E"; // mdi battery 0
// Akku-Symbol und Ladezustand
it.printf(740, 40, id(font_mdi_medium), TextAlign::CENTER, "%s", icon.c_str());
it.printf(757, 120, id(small), TextAlign::CENTER, "%.0f%%", ladezustand);
captive_portal:
time:
- platform: homeassistant
entity_id: sensor.byd_battery_box_premium_hv_ladezustand
name: "Solarnet Netzbezug"
entity_id: sensor.solarnet_leistung_netzbezug
name: "Solarnet Netzeinspeisung"
entity_id: sensor.solarnet_leistung_netzeinspeisung
name: "Solarnet PV Leistung"
entity_id: sensor.solarnet_pv_leistung
name: "Solarnet Verbrauch"
entity_id: sensor.solarnet_leistung_verbrauch
