Yes, I can confirm (after updating to 0.82.1 just now) that the custom component still works.
Please share your redacted config. Did you put the python script in the correct directory?
Hi bram,
I get this message now:
Platform not found: climate.e_thermostaat
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: *******
longitude: *******
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 60
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Amsterdam
Customization file
customize: !include customize.yaml
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
api_password: !secret http_password
base_url: example.duckdns.org:8123
ssl_certificate: /etc/letsencrypt/live//fullchain.pem
ssl_key: /etc/letsencrypt/live/****/privkey.pem
ip_ban_enabled: True
login_attempts_threshold: 5
Checks for available updates
Note: This component will send some information about your system to
the developers to assist with development of Home Assistant.
For more information, please see:
https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time
history:
View all events in a logbook
logbook:
Enables a map showing the location of tracked devices
map:
Track the sun
sun:
Sensors
Weather prediction
- platform: yr
E-Thermostaat Icy
climate:
- platform: e_thermostaat
username: !secret icy_username
password: !secret icy_password
comfort_temperature: 20
saving_temperature: 15
away_temperature: 12
Text to speech
tts:
- platform: google
Cloud
cloud:
SABNzbd
sabnzbd:
api_key: !secret sabnzbd_api
host: ************
sensors:
- current_status
group: !include groups.yaml
script: !include scripts.yaml
the e_thermostaat.py file is in .homeassistant/config/custom_component
kind regards ivo frenken
I think the folder should be custom_components instead of custom_component.
Does that work?
Thanks for that information. I got it working today. first I changes the name to custom_components, like freakshock told me. Then I moved the folder from /config to .homeassistant, so to the root folder where the configuration script is.
Kind regards,
Ivo
If for some reason this custom component stops working with new HA releases, it is also possible to make it work with MQTT and Node-Red and defining the thermostat as a MQTT climate device in HA. It is a simple interface, you can only get and set the temperature. But who needs the predefined states if you use HA
I got it working with the google assistant but it is kind of a dirty fix in the e_thermostaat.py:
STATE_COMFORT = "heat" # "comfort"
STATE_SAVING = "cool" # "saving"
STATE_AWAY = "off" # "away"
Since the google actions api on temperature settings only accepts āoff/heat/cool/heatcool/autoā and does not know how to handle ācomfort/saving/awayā , I changed the values and got it working.
Especially the STATE_SAVING = "cool" # "saving"
is not so nice, since you arenāt actively cooling, but I wanted that mode to be available to my Assistant.
Hope this helps
I have another question. Has anyone build an automation for this, using the different states (comfort/saving/away/fixed temperature)?
greetings,
ivo Frenken
Yes that works fine. If you are using the version from my Github you have to use the Dutch names though. Here is a working example for the action part of an automation.
- service: climate.set_operation_mode
entity_id: climate.ethermostaat
operation_mode: Comfortstand
Thnx Tanto, tried it and it works.
Great find, thanks!
@gerard33, perhaps you should change this in your Git, if also fixes the mode changing in Lovelace!
There is something strange happening with the automation I have build for the e-thermostat. The action form gerard33 works. But my automation doesnāt It starts at the time I want, but it end before I want it.
It looks like:
alias: Verwarming aan weekdagen ochtend
trigger:- at: ā05:00:00ā
platform: time
condition:
- at: ā05:00:00ā
condition: time
weekday:- mon
- tue
- wed
- thu
- fri
platform: time
condition: - condition: time
weekday:- mon
- tue
- wed
- thu
- fri
- at: ā05:00:00ā
I hope someone knows what Iām doing wrong.
Can you post your automation using code block, see the top of the page on how to do this.
And at what time does the thermostat start and end?
This is the code block. I checked this morning, it started at 05:00:00 (comfortstand). then at 05:20:00 it changed to bespaarstand. It should do this at 07:00:00. What can I change to make this happen?
# Verwarming #
- id: verwarming-aan-weekdagen-ochtend
- at: '05:00:00'
platform: time
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- id: verwarming-uit-weekdagen-ochtend
alias: Verwarming uit weekdagen ochtend
- at: '07:00:00'
platform: time
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
operation_mode: Bespaarstand
- id: '1543219439438'
alias: Verwarming aan weekdagen middag
- at: '16:00:00'
platform: time
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- id: '1543220075868'
alias: Verwarming uit weekdagen middag
- at: '17:30:00'
platform: time
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
I see some indents which arenāt right (could be caused by pasting) and I suggest to start the trigger with time.
Can you try it like this?
- platform: time
at: '05:00:00'
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
And can you also check you have disabled all timers and havenāt set a period for the Comfortstand on https://www.e-thermostaat.nl/?
I have changed the config. Also I checked if there are any timers on the essent site, but there arenāt. I have set a period for the Comfortstand and that is 90 minutes. So it should not stop after 10 or 20 minutes.
I was thinking if it would be better to make an other trigger. Something like, if the temp is lower than 20 and the time between 05:00:00 - 07:00:00 and weekdays mon - fri. Would that work better?
Iām having the same problem, somehow the thermostat switches back to cooling mode 20 minutes after enabling heating mode in the morning.
I recently started using these modes instead of the āVaste temperatuurā mode I was using before. Iāll try to switch back and see if this has better results and report back.
Perhaps the settings on e-thermostaat.nl are not actually configured in the hub after changing them, it seems 20 minutes is the default setting to reset to āBespaarstandā
Users of the E-thermostaat received an email this morning explaining that the collaboration between Essent and ICY stops from 1 February 2019. After this, if there is enough interest, ICY will keep itās services available for ā¬1,95 per month.
More info here:
Too bad, Iām not going to pay 2 euroās per month just for the service.
Does anyone have a nice alternative to the ICY thermostat thatās affordable (under 100 euroās), with the same functionality in HA, without a subscription? Preferably with local control?
I am using homematic IP radiator thermostats now, with a selfmade CCU (the homematic control unit) on a rasperry pi, this all local. So I do not use the Homematic IP cloud at all. But it is a bit more expensive, as I use radiator thermostats instead of one central thermostat I need one per radiator. Setting up the rasperry pi as CCU is just a matter of buying the Homematic control kit for rasperry pi and downloading an image.
