Am experiencing the same. So at least you’re not alone. Read about someone else having the same issue and then after charging for the first time the entities were updated. However I haven’t got my car yet so cannot try that out.
Hey Guys, I am running the Eease charger and load balancer. I get all data but the load balancer is giving me values in x.x kW. Is there a way to get it to report Watts instead of Kilowatts?
Is there any way to add somekind of history of power usaged? like over a certain amount of time say a month? i can see the api call for it is there, but i dont seem to be able to select any kind of Entities for that kind of info?
Hi. I’ve got an Easee charger and have installed the integration in HA. Everything works, however when I add the device to the Energy dashboard, I’m only able to add the “XXXXXX Lifetime energy”.
It works in the dashboard for daily/weekly/monthly usage, but when dig into detailed view, you only see the aggregate consumption.
How do I add the “XXXXXX Power” entity to the energy dashboard like is shown for all other devices I have (mostly shelly plugs)?
Wondering why it’s the lifetime energy entity that shows up.
Easee Load Balancer connects to the same P1/HAN port. So I would have disconnect ESP32 and connect Easee LB instead. Anyone knows if it is possible to connect two devices to P1 port or in some other way solve this?
I haven’t got Equalizer yet and only have p1 esphome which feeds the data from the electricity meter into hass.
When I will get Equalizer I still want to continuity getting data into hass via esphome.
But let me rephrase the question after reading your last post. Can I get all the consumption info (not only related to EV charging) from the meter using Equalizer? Info like current used, voltage, kwh per phase?
Yes, you get the data in general, not only the charging robot data. You get the current in kW, voltage and ampere per phase (not kW), and kWh in total.
