Hello all,
I am trying to control my vaillant ecotec boiler.
I built an adapter that can be found at https://github.com/xyzroe/eBus-TTL-adapter/ and connected to an esp wroom32
I tried to integrate with esphome + ebusd on ha
esphome code is uploaded and connecting to ebusd.
But i dont see any scan or detection of boiler.
is there anybody that used this pcb?
I’m interested in this too, especially to enable an ESPHome programmed ESP32-C3 board for communication with the eBusd integration. Have a homegrown adapter with some additional features. While my hardware is different, I will try to use your software approach to see if there are problems on side of the software.
What I see as possible problems at the hardware in your approach: The adapter has 5V TTL-levels, that is too high on the RX-pin for ESP, they need 3.3V max. More voltage can lead to damage or other problems. It’s easy to fix: Just connect the 5V pin of the connector to the 3V3 supply of the ESP. The TX-pin may see a bit of overload, you can replace R13 with a 560-1k one. The LEDs don’t need that much current. While I have some doubts that this really causes TX to fail, at least the 5V/3V3 should be fixed.
