Ebusd: Integration failed to initialize
I have purchased an ebus adapter v3 with a Wemos D1 mini on top and wired it to my Vaillant heating system.
Ebusd is runnung on a machine with ip 192.168.178.5 on port 8888. The ebus adapter connects successfully to my heating system:
grafik
Also ebusd detects the heating properly when running ebusctl info:
version: ebusd 21.1.v21.1-3-g62221bb
update check: version 21.2 available
signal: acquired
symbol rate: 40
max symbol rate: 78
min arbitration micros: 2
max arbitration micros: 23
min symbol latency: 8
max symbol latency: 13
reconnects: 0
masters: 3
conditional: 13
poll: 0
update: 10
address 03: master #11
address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0518;HW=7401", loaded "vaillant/bai.308523.inc" ([PROD='0010004279']), "vaillant/08.bai.csv"
address 10: master #2
address 15: slave #2, scanned "MF=Vaillant;ID=39200;SW=0215;HW=2002", loaded "vaillant/15.392.csv"
address 31: master #8, ebusd
address 36: slave #8, ebusd
The only thing that does not seem to work is the homeassistant ebus integration:
grafik
My config is:
ebusd:
  host: 192.168.178.5
  circuit: "bai"
Can anyone help out?
Any luck with your problem? I’ve got same setup (different heater, but this is not important). And also unable to get it working.
The answer is simple: Do not use ebusd component but instead use mqtt to get and set values. I never got the native component to work.
Could you share some configuration examples? I’ve got heater and I’m (for now) only interested in displaying it’s status on dashboard (temperatures, flame status, gas usage).
When I run in console:
mosquito_sub -v -t "ebusd/#"
I periodicaly get data from subjects like: ebusd/bai/FlowTemp, ebusd/bai/WaterPresure, etc.
I probably should setup MQTT Sensor (MQTT Sensor - Home Assistant), but I’m unsure.
Edit:
Yuppi, added into configuration.yaml this code, and got data:
- platform: mqtt
  state_topic: "ebusd/bai/FlowTemp"
  value_template: "{{ value_json.temp.value }}"
