Thanks for the suggestion. I removed the quotes and restarted. That seemed to have resolved some of the issue, but now I’m getting a different error about not being able to connect to Amazon.
Also, I’ve not yet seen the Catcha appear on the frontend UI since my reinstall yesterday.
Here’s the error from the logs:
Log Details (ERROR)
Sun Dec 23 2018 06:28:52 GMT-0500 (Eastern Standard Time)
Error while setting up platform alexa
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7010b490>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='alexa.amazon.com', port=443): Max retries exceeded with url: /api/devices-v2/device (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7010b490>: Failed to establish a new connection: [Errno -3] Try again',))
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/config/custom_components/media_player/alexa.py", line 142, in setup_platform
config.get(CONF_DEBUG))
File "/config/custom_components/media_player/alexa.py", line 608, in __init__
self.login_with_cookie()
File "/config/custom_components/media_player/alexa.py", line 631, in login_with_cookie
self.login(cookies=cookies)
File "/config/custom_components/media_player/alexa.py", line 747, in login
resp = self._session.get(site)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='alexa.amazon.com', port=443): Max retries exceeded with url: /api/devices-v2/device (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7010b490>: Failed to establish a new connection: [Errno -3] Try again',))
Any thoughts @keatontaylor? Thanks to everyone.
