EDIT: I fixed it by removing the quotes around amazon.co.uk in the config file!
Thanks @keatontaylor! This is a great piece of work!
Original comment follows:
So, with the right Alexa.py file, I passed the config check and restarted ok-ish. But the Alexa component is not working. I get a lot of errors in my log. I really don’t understand how to parse this
Any help much appreciated. I would love to get this component working!
2018-12-28 00:33:47 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.alexa which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-12-28 00:33:49 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up platform alexa
File “/usr/local/lib/python3.6/site-packages/requests/models.py”, line 350, in _get_idna_encoded_host
host = idna.encode(host, uts46=True).decode(‘utf-8’)
File “/usr/local/lib/python3.6/site-packages/idna/core.py”, line 361, in encode
s = alabel(label)
File “/usr/local/lib/python3.6/site-packages/idna/core.py”, line 284, in alabel
check_label(label)
File “/usr/local/lib/python3.6/site-packages/idna/core.py”, line 261, in check_label
raise InvalidCodepoint(‘Codepoint {0} at position {1} of {2} not allowed’.format(_unot(cp_value), pos+1, repr(label)))
idna.core.InvalidCodepoint: Codepoint U+201C at position 1 of ‘“amazon’ not allowed
File “/usr/local/lib/python3.6/site-packages/requests/models.py”, line 398, in prepare_url
host = self._get_idna_encoded_host(host)
File “/usr/local/lib/python3.6/site-packages/requests/models.py”, line 352, in _get_idna_encoded_host
raise UnicodeError
UnicodeError
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/config/custom_components/media_player/alexa.py”, line 146, in setup_platform
config.get(CONF_DEBUG))
File “/config/custom_components/media_player/alexa.py”, line 618, in init
self.login_with_cookie()
File “/config/custom_components/media_player/alexa.py”, line 641, in login_with_cookie
self.login(cookies=cookies)
File “/config/custom_components/media_player/alexa.py”, line 757, in login
resp = self._session.get(site)
File “/usr/local/lib/python3.6/site-packages/requests/sessions.py”, line 546, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/local/lib/python3.6/site-packages/requests/sessions.py”, line 519, in request
prep = self.prepare_request(req)
File “/usr/local/lib/python3.6/site-packages/requests/sessions.py”, line 462, in prepare_request
hooks=merge_hooks(request.hooks, self.hooks),
File “/usr/local/lib/python3.6/site-packages/requests/models.py”, line 313, in prepare
self.prepare_url(url, params)
File “/usr/local/lib/python3.6/site-packages/requests/models.py”, line 400, in prepare_url
raise InvalidURL(‘URL has an invalid label.’)
requests.exceptions.InvalidURL: URL has an invalid label.
