Hi
I am looking for a dimmer with a turning knob that i can add in my home assistant.
I have a z-wave stick and have found the Eco-dim.07 Z-wave.
Is there anyone that have added this device to home assistant? Will it work ”out of the box” or will i have to do a lot of configuration?
Hi Markus,
Over the weekend I have added the first model of the Eco-dim.07 which has both Z-wave and ZigBee using the AEON Labs ZW090 Z-Stick Gen5 EU.
Below what was discovered which seems to be incomplete, but otherwise on/off/dimming is working, and is also reported when doing it on the dimmer itself.
zwave.unknown_id_0431_unknown_type_0202_id_0001_2
node_id: 10
node_name: Unknown: id=0431 Unknown: type=0202, id=0001
manufacturer_name: Unknown: id=0431
product_name: Unknown: type=0202, id=0001
query_stage: Complete
is_awake: true
is_ready: true
is_failed: false
is_info_received: true
max_baud_rate: 40000
is_zwave_plus: true
capabilities: beaming, listening, routing, zwave_plus
neighbors: 1
sentCnt: 135
sentFailed: 0
retries: 1
receivedCnt: 357
receivedDups: 116
receivedUnsolicited: 243
sentTS: 2020-04-06 08:07:57:975
receivedTS: 2020-04-06 08:07:58:014
lastRequestRTT: 25
averageRequestRTT: 26
lastResponseRTT: 39
averageResponseRTT: 39
application_version: 1.17
friendly_name: Ecodim.07 Z-Wave dimmer
light.unknown_id_0431_unknown_type_0202_id_0001_level
node_id: 10
value_index: 0
value_instance: 1
value_id: 72057594210516993
friendly_name: Licht Keuken
supported_features: 33
Curious to hear how it goes at your end!
I have the same situation. Did you fixed it to get the complete configuration ?
Unfortuanately not. Quite happy that the basic functionality is working, i.e. on of and dimming.
