Ecobee Broken after update to 0.66
Hi all has anyone had issues with Ecobee after upgrading to 0.66? I am running in a Python Virtual Env on Rpi. Seeing the following errors in the startup log and do not see any of my ecobee entries in the web UI.
Apr 01 21:34:48 pihole hass[1078]: 2018-04-01 21:34:48 WARNING (MainThread) [homeassistant.setup] Setup of ecobee is taking over 10 seconds.
Apr 01 21:34:48 pihole hass[1078]: 2018-04-01 21:34:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: message=Setup of ecobee is taking over 10 seconds., source=bootstrap.py, timestamp=1522632888.0943787, exception=, level=WARNING>
Apr 01 21:36:51 pihole hass[1078]: 2018-04-01 21:36:51 WARNING (Thread-10) [pyecobee] Error connecting to Ecobee.  Possible connectivity outage.
Apr 01 21:36:51 pihole hass[1078]: 2018-04-01 21:36:51 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: message=Error connecting to Ecobee.  Possible connectivity outage., source=components/ecobee.py, timestamp=1522633011.2865174, exception=, level=WARNING>
Have you try removing the ecobee.conf file and restart?
I had that before, removed the file and got re-authorize ecobee request after restart.
Don’t know where that file is in hass.io, in Hassbian, it’s in /home/homeassistant/.homeassistant.
