Could some verify that what I’m seeing is what should be expected. I am using the ecobee integration- the one that uses the api- and for some reason the smartsensors that I have linked to the thermostat didn’t come into home assistant with the thermostat.
Can this be fixed or “it is what it is”. I learned that the ability to use the built in Siri on the thermostat isn’t available if I use the “HomeKit Device” integration to bring the thermostat into home assistant. This method does bring the smartsensors in also though.
Can someone verify what I am seeing is what they saw or am I doing something wrong in the cloud ecobee integration.
