Ecobee Thermostat Replacement bad Display
My Ecobee Thermostat Display is going bad. I need to replace it. I am slowly moving my house to HA. But I noticed on the compatibility list that Ecobee shut down API access. If I buy another Ecobee is this an issue with using a new Ecobee Thermostat? Or does any one have a recommendation on a good Thermostat for use with HA other then Ecobee.?
You can control Ecobee thru the Homekit Device integration without needing the API key if you want to stick with Ecobee.
@Stephenn Thanks for the Info.
However… note that the Homekit integration does not expose all of the attributes that the native API-required integration does. Here are the sensors I can see using Homekit. There is no way, for example, to tell if the system is using Aux or regular heat, or what stage of cooling is running…
