EcoFlow API Integration - Official Developer API + MQTT (Delta Pro 3)
EcoFlow API Integration for Home Assistant
Home Assistant integration for EcoFlow devices using the official EcoFlow Developer API with optional MQTT real-time updates.
:glowing_star: Features
  • :white_check_mark: Hybrid Mode - REST API + MQTT for real-time updates
  • :white_check_mark: Official API - Uses EcoFlow Developer REST API (stable & documented)
  • :white_check_mark: Complete Delta Pro 3 support - 40+ sensors, 13 binary sensors, 9 switches, 13 controls
  • :white_check_mark: Real device tested - All features verified with actual Delta Pro 3
  • :white_check_mark: Energy Dashboard ready - Automatic kWh sensors for HA Energy Dashboard
  • :white_check_mark: Battery monitoring - BMS data, SOC, SOH, temperature, cycles, capacity
  • :white_check_mark: Power monitoring - Input/output, AC, Solar (HV/LV), DC, USB-C, USB
  • :white_check_mark: Full control - AC charging power, charge levels, standby times, X-Boost
  • :white_check_mark: Extra Battery support - Automatic detection and monitoring
  • :white_check_mark: Ukrainian localization :ukraine:
:package: Installation
HACS (Recommended)
Manual
  1. Copy custom_components/ecoflow_api to your config/custom_components/
  2. Restart Home Assistant
:gear: Configuration
  1. Get API keys from EcoFlow Developer Portal
  2. Go to Settings β†’ Devices & Services β†’ Add Integration
  3. Search β€œEcoFlow API” and follow the setup wizard
:counterclockwise_arrows_button: Hybrid Mode (REST + MQTT)
The integration supports hybrid mode combining:
  • REST API - Reliable device control
  • MQTT - Real-time sensor updates (no polling delay!)
Enable MQTT in integration options for instant updates.
:bar_chart: Entities
Type Count Examples
Sensors 40+ Battery level, power, temperature, remaining time
Binary Sensors 13 Charging, discharging, AC connected, battery full
Switches 9 AC output, DC output, X-Boost, beeper
Numbers 13 Charging power, charge levels, standby times
Selects 4 AC frequency, standby times
:globe_showing_europe_africa: Supported Devices
Device Status
Delta Pro 3 :white_check_mark: Full Support
Delta Pro :counterclockwise_arrows_button: Planned
Delta 2 / 2 Max :counterclockwise_arrows_button: Planned
River 2 / 2 Max :counterclockwise_arrows_button: Planned
:books: Links
:handshake: Contributing
Contributions welcome! Please open issues or PRs on GitHub.
Made with :heart: in Ukraine :ukraine:
Note: This is a non-commercial project. Commercial use is prohibited.
Does this integration run entirely locally after setup?
No, this integration does NOT run entirely locally. It requires internet connection because:
  1. REST API - connects to EcoFlow cloud servers (api.ecoflow.com)
  2. MQTT - connects to EcoFlow MQTT broker (mqtt.ecoflow.com:8883)
EcoFlow does not provide a local API. All communication goes through their cloud infrastructure.
If you need local-only access, consider:
  • EcoFlow BLE integration (Bluetooth, limited functionality)
  • Note: Most EcoFlow integrations require cloud access
Does it also retrieve PowerStream data or ONLY delta pro 3?
Delta Pro 3 :white_check_mark: Full Support All features, real device tested
Delta Pro :white_check_mark: Full Support US API verified
Delta 3 Plus :white_check_mark: Full Support All features
River 3 :white_check_mark: Full Support All features
River 3 Plus :white_check_mark: Full Support Same API as River 3
Your post suggests it River 3 is now supported, but I can’t see it in the list of devices as of v 1.8.4. What am I missing?
working better than ecoflow cloud for my stream ultra x, hope the river 2 pro will be supported soon
Got a question about Automatic Fallback : does it comes back to MQTT after Fallback to Rest-Mode ? Any Log ?
Will this integration also work for a Ecoflow Delta 3?
Can you make this work with the Ecoflow Delta 3 Plus? :pray:
Thanks in advance!
Works well with my PowerStream but I have Delta Max 2000 connected, any chance of including support for the Delta Max product, Big problems getting the tolwi integration to talk to Delta Max 2000
Anyone using the new EcoFlow Ocean 2 devices with this integration?
