EchoWitt and YoLink pre-purchase advice
I’ve searched the forums and found quite a bit of configuration advice, but I’m trying to stay one step ahead and ask for some pre-purchase advice before I start buying hardware.
My use case is at a vacation rental property. I’d like to integrate:
- YoLink depth/water level sensors in both a creek and a lake
- An EcoWitt weather station
- Home Assistant dashboard visibility for guests on a screen in the kitchen
- Remote access for me when I’m off-site, mainly so I can see weather conditions and monitor potential flooding conditions on both bodies of water
This is not a life-safety system, so I don’t need anything industrial-grade, highly redundant, or overly robust. It’s partly practical and partly “just because it would be useful and fun to have.” Internet is strong there.
My main questions are:
Is EcoWitt generally considered one of the better weather station solutions for Home Assistant integration, or is there another brand/setup I should be looking at before I buy?
For YoLink, I’m a little unsure which hub makes the most sense. They have a more expensive hub that mentions things like Matter integration and MQTT. I’ve done some reading on both, but I’m not sure whether I actually need those features for this use case.
For a mostly remote-monitoring setup like this, would I be better off keeping it simple with the standard YoLink hub, or is there a good reason to spend more up front for the hub with Matter/MQTT support?
Any advice from people who have already integrated EcoWitt and/or YoLink with Home Assistant would be appreciated. I’d rather buy the right pieces the first time than discover later that I should have gone a different direction.
